Re: What is inside out turning?
ben d.
>This is a copy of a post form Ken Grunke on the subject. The pictures with the post did not copy, but you can do the search and get those.
Re: inside out petal vase
Posted By: Ken Grunke from SW WI kengrunke@crwoodturner.comma
Date: Thursday, 15 December 2005, at 6:55 p.m.
In Response To: inside out petal vase (bob davis)
Bob,
In a nutshell, here's how I did it:
Start with 4 square sticks, temporarily glue or otherwise fasten them together using one of several different methods, which will allow you to seperate the 4 pieces after the first, inside turning step which looks like this on the petal vases I made:
The traditional method for temporary glue up is carpenter's glue with a layer of brown bag paper in the joint to make it easy to seperate with a chisel.
Thin-film double-stick tape works well also, if you apply heavy pressure with a c-clamp for a few seconds to strengthen the bond.
Most woodturners these days have a 4-jaw scroll chuck which can be used to hold one end of the 4-piece assembly, so you only have to bond a small portion of the tailstock end to keep the tailstock point from wedging the assembly apart but also to make it easier to seperate the temporarily fastened pieces after the first stage of turning. Whatever bonding method you use, it's only needed for 50% or less of the total length at the tailstock end to make it easier to pry the segments apart at the headstock end after turning the first stage for the inside profile.
After the inside profile is turned, sanded and finished, seperate the segments, reverse each one so the turned profile is facing inwards, and glue them permanently together so they look like this:
For the final turning on the outside, I would turn a scrap piece of wood in the chuck to an inside curved cone shape which fits the profile of the top inside to act as a drive cone at the headstock end. The tailstock end is held by the tailstock point at the center intersection between the four segments. For padding on the drive cone, I use thin craft foam sheets with peel-off backing available at craft stores or Walmart with the name "Foamies", in 9 x 12" sheets for about 60 cents each. Turn the outside profile to follow the previously turned inside, something like this or whatever your imagination comes up with:
That's basically it--any more questions, ask here
