How do you?
Rick Davenport
>How do you sign your pieces?
I've been using a Dremel engraver and I think it's tacky.
What's your preferred method for signing your works of art?
Especially bowls.
Thanks,
Rick "Tearout" Davenport
Edmonds, WA
How do you?
Rick Davenport
Especially bowls.
Thanks,
Edmonds, WA
Re: How do you?
Jim Shaver - Oakville, Ontario
>Hi Rick,
I sign my work after I have the finish applied. What I do is I use the Dremel engraver, then I rub in some dark wax and rub it out. Since the piece was finished prior to using the engraver the wax only penetrates the signed area..I like it.
take care,
Jim
Re: How do you?
>I like the dremel engraver. You do have to practice your handwriting to make it look good. Some people rub colored wax in to make it look better. Everyone has to find what works for them. I tried pens and woodburning and to me it just didn't look as good. Some of the Gold pens looked good but not on all wood. The black pens had the same problems as did woodburning. The engraver works on all woods no matter what the color.
Ditto on engraver
Ken Grunke from SW WI
>If you go a little too fast, it breaks up into dots. I take it slow and with very little pressure, kind of like using a high-speed rotary engraving tool--and try to write as small and fancy as I can. That's getting harder the older I get.
Re: How do you question?
ken chase
>Is the engraver a dedicated tool or can an ordinary dremel tool be fitted with an engraving bit?
JKJ in East TN
The engraver is a separate tool. It is difficult to engrave with a rotary tool although I have done that in a pinch with a fine conical bit. The engraver is quite inexpensive - I got one at Home Depot or Lowes.
Instead of a rotary action, it vibrates the tip rapidly in a reciprocating action. This lets you easily "write" on things as you would with a pencil. It has a hardened tip and was intended to engrave on metals, but it also works well on plastic. It works less well on wood due to the variability of the grain. For wood, I think it helps to grind the tip to a sharper point.
BTW, I use a fine point sharpie. I've tried woodburning but I'm too sloppy. I don't like the looks of the engraver, but maybe I just need more practice.
Re: How do you?
RevDoug
>I'm using a white paint pen right now. Don't really like it, but I can use it better than I can a rotary tool.
Turn 'em round,
Optima wodburner
Jorge Castaneda
Dremel Engraver
Jennifer@Indy.USA
>I've tried em all and have settled on the engraver. I set the unit on #2 any higer and it's too vibrating and makes the signature look scribbely.
I agree...at first my signature did look tacky. It does take some practice to get it to look descent. I hope it doesn't still look tacky? Yikes!
Jennifer
What wood?
Jay Kilpatrick in TX
>Most light to medium dark woods get a burnt signature. Dark ones get the fine conical dremel bit signature with liming wax rubbed in.
Re: How do you?
Rick Davenport
>It looks like I'm going to stick with my Dremel engraver and get some waxes that contrast with the wood I am working with.
And practice my signature.
A lot.
Thanks for the advice folks.
Rick
Re: Thanks!
ken chase
