Horizontal Drill On The Lathe
Jim Shaver - Oakville, Ontario
>Hi
Sometimes it�s takes me awhile to see the obvious opportunity with my lathe. I have used a drill chuck mounted in the tail stock many times to drill into my work on the lathe, from pepper mills to bowl blanks, it�s been accurate and easy.
I guess a awhile ago I was revisiting the way I drill some of my more expensive pen blanks. I have been using a drill press and a small drill press vise for about 6 years. It always makes me nervous when I am drilling a 37/64 hole into a 7/8 square blank that cost me $$ to not come out the side of the material or have such small edge distance that it will turn undersize on the ends for the given hardware.
Recently I was given a keyless chuck as a Christmas present ( I love it!). Thinking I might try something different I decided to give drilling a pen blank on my mini lathe a try. I took a 7/8 pen blank and set it up in my Talon chuck with spigot jaws, then used my drill chuck with a 37/64 drill and horizontally bored a hole into a beautiful piece if Italian Lucite��.perfectly right down the centre�the entry point on the face was perfectly in the middle and the exit point the same�.WOW, how amazing, AND no stress on the ol� ticker either (phew)!!
So tonight I set the same configuration up on my Jet Mini and was able to drill out 25 Cigar blanks in a hour! For me that is pretty fast. The all came out great, right down the middle.
I am getting another set of pens ready to go for Pens For Canadian Peacekeepers so these blanks are part of that shipment to go along with another 15 donation pens I have.
Anyway, just wanted to pass along my good results using horizontal drilling�the spigot jaws really are wonderful to have on the Talon by the way.
Nice to be in the shop tonight� kind of cold on the hands �but a nice feeling to be busy.
Take care,
Jim.
Re: Horizontal Drill On The Lathe
Tom In Red Deer
>Hi Jim,
I had thought of that but hadn't tried it just yet. A silly question ... I too have the spigot jaws on one of my chucks. Did you mount the blank by the flat sides or the edges?
Tom
>Hi Tom,
I used the faces of the blank against the jaws.....some were not squre so I used set it as best I could by eye and indexed on the third face.
Hope that helps,
take care,
Jim
Jake Niedling
>Jim,
This is the approach I have been using and it has worked great like you said. I don't turn very many pens, so did not want to build a jig or buy one for my drill press. I don't even change my jaws to the smaller size on my stronghold, I just open up the jaws, put into the center and tighten the jaws up on the pen blank.
Al Crandall (NE of Indy)
>Hi Jim. I've never turned a pen, but coming from a tooling background, it has always amazed me that pen turners go to a drill press to use a "special" vise bought just for drilling pens when the lathe is sitting right there. For those who will say that they don't have a four jaw chuck to do as you have just done, I say put the drill chuck in the headstock and rest the pen blank cross wise on the toolrest, and push the blank onto the spinning drill with the live center in teh tailstock. If you fear that the drill will run off center, drill half way through it from each end and then cut it to the required lengths.
They're PeaceMakers, Jim
Garrett in Victoria
>Too many casualties and violent engagements, and no peace yet to keep.
I know your thoughtfulness is very much appreciated.
Cheers, Garrett
Re: They're PeaceMakers, Jim
>Thanks Garrett,
I appreciate your words of support...they are hero's
take care,
Jim
eaglesc
>I don't have any kind of chucks that you mention,for accurate drilling to the center of a patterened blank I turn the blank round between centers and then use my beall collet.
Same principle.
Accuracy
