We value your privacy.
>Here in the "hardwood deprived" high country of Colorado, I turn quite a bit of engineered materials. Plywood mostly. You really want hardwood plys throughout. This means Baltic Birch ply or Marine grade lauan ply. I scored some great stuff from some spiral stair treads that were being torn down. Thick plys and all hardwood. Never seen any before or since.
Glue up with plenty of glue and clamps. Use respirator and dust collection as you're never sure what kind of glue they use for the plywood. Can be Urea resin which is a known carcinogen I believe. Nasty stuff either way.
Plywood is no fun to turn, but can yield striking results. Play around with it, start small with eggs or a small bud vase or something, see if you like it.
>I've turned a couple bowls out of regular Home Depot plywood. I didn't pay any attention to the few voids as I was just working on form. I did finish one by painting tinted epoxy and allowing the it to fill the voids. I then did the finishing cuts which left the occasional colored spot. All in all it came out rather well.
I enjoy turning Baltic birch 9 ply plywood laminated several times, , fewest voids of all plywood's and some spectacular results. The dust and sanding can be annoying but well worth the effort as Dave just showed.
>That's really a great bowl, I was in a shop about a month ago and they had boxes made from plywood. What the guy/gal had done was to sand/carve the top and sides so the laminates of the plywood were exposed. Then they stained it and put a sating type of finish. Once I realized what they had done, I realize they were really pretty ingenious in how they used the wood.
