Re: Kind of what I figured...(pretty doggone long)
Gary Evans Tallassee, TN
>Steve,
A couple of thoughts. I had good luck flattening a platter that I turned from green Camphor. I was talking to one of the pro's (Al Caton) this weekend about the behavior of Camphor and he tells me that it tends to develop small cracks in the endgrain that are relatively shallow. He also says that you can let it set for years and that is all the cracking that will occur. I picked up a couple of pieces of 2-year old camphor this weekend and I can say from my limited observation, that he is correct.
I know from experience that cherry cracks tend to be large and deep. I have seen cherry logs that were cracked 3 or 4" outward from the pith after laying a couple of years. In the middle of a 10' log! This leads me to believe that Camphor is much more resistant to drying stresses than Cherry.
But, how does this help you? I think the only way to be succesful with drying cherry under pressure would be to get it into your drying press while it is still as wet as possible, as you suggested. If it starts to dry out at all, then you are trying to manipulate dry, shrunken cells, which will reduce the odds of a successful result.
You also need to be careful about the drying conditions if you get it into the drying rack without a crack. The lower the relative humidity, the greater the shock for the wood cells. As wood dries, though, it gets stronger and can resist more drying stress. The trick is to keep it in relatively high humidity and low temperature initially, with just enough ventilation to prevent the growth of molds. I have an unheated shop next to a creek, so I kept my Camphor platter out there for about 6 weeks in the early summer before I brought it into the house. I haven't seen more than 1/8" of movement in the several months that we've had it in the house.
Sorry for the ramble,
Gary
