Thanks for Spindlemaster advice.
Phil Axtell
>Thanks guys,
I really appreciate all your good advice. I will start trying to repair my Spindelmaster in the next few days. I contacted Robert Sorby and will wait to see what they have to say before trying anything.
I will post my results here as soon as I can.
This is certainly a great group when you need advice.
I will put this in a new thread for those who don't scroll down this far.
Thanks again,
Phil Axtell
Re: Thanks for Spindlemaster advice.
RussFairfield
>Both the Spindlemaster and the Skewchigouge are old tools, from the days before fluted spindle gouges, that have been reintroduced to todays woodturners. There is nothing magical about them. They are a spindle gouge without a flute, and they are they way they are because they are easier to make and grind. The only difference is that one is round and the other is flat; and there are versions that are half-round.
Both are used like a spindle gouge, and both can be ground like a spindle gouge. There is nothing magical about the flat bevel. The wood only sees that small area immediately below cutting edge, and that is 1/32" wide, or 1/16" at the most. The rest of the bevel is just along for the ride and does nothing to make it a better tool.
You can polish or hone the concave bevel off the grinder because that can make it a sharper tool and the sharper the tool the better the cut, whether it is a spindle gouge or one of these tools. You can use a belt of disc sander if you prefer to have a flat bevel.
A lot of people have catch and control problems with these tools. The only reason that I can see is that they come from the factory with too small an angle between the bevel and the top of the tool for most people. These behave no different from a spindle gouge - the greater the angle the easier it is to use, but the worse the finish. The opposit is also true, the less the angle between the bevel and the top of the tool, the better the finish, but the more difficult it is to control. The ones I have seen came with a 25-degree angle, and that is too shallow for most people. Regrinding it to a 45-degree tool angle would be easier to use.
Anyone having a catching problem with a Spindlemaster or Skewchigouge should regrind the tool to a 45-degree tool angle and try again. Then gradually move to a shallower angle as they gain experience with the tool. The same is true for a spindle gouge or a skew.
Phil Axtell
>Hi all,
Well, I shipped my Spindlemaster off to Sheffield, England to Robert Sorby. They told me they would be happy to repair my tool to new condition if I would just send it to them and pay the freight. That's what I did and should get it back next week.
I probably took the coward's way out, but now I shouldn't be disappointed with the results. I will NOT stick it into the chuck again!
Thanks all of you for your great advice.
Phil Axtell
