Cutting blanks on the band saw
Jim Dickman
>I free hand my wood blanks on the band saw. I'm interested in what others are doing to safely and easily cut out round blanks. I use a 3/4" 3-4 TPI blade now. I think I need a thinner blade...
Any jigs out there that make it easier?
Jim
Re: Cutting blanks on the band saw
Cutting blanks
ob obrien In Pensacola
>Cut some different sized circles out of thin plywood. Make a hole in the middle, the size of a nail. Select the size blank you want and slide it back and forth on the uncut blank to use the best grain orientation. Tack it on with the nail and use the edge of the plywood as a guide to cut your blank. Now you also have a centering mark for your lathe where the nail hole is. Works for me. OB
Mac
>Try a 1/4" blade.......works for me.........3 or 4 teeth per inch....
Keith Tompkins
Keith Tompkins
>HI JIm, yes , you need a new blade. The 3/4 blade is primarily for resawing stock.I would suggest a 1/2 or even 3/8" blade.
I personally don't recommend any type of guide pins because, if the blade drifts in thick stock, and the blank cannot move to accomodate this, you will be breaking blades on a regular basis.
A couple of safety pointers: always keep a flat surface on the bandsaw table, avoid pieces that rock on the table. Avoid cutting round stock unless it is secured in a jig or clamping device. When cutting blanks, the most dangerous point is where the blade comes close to the edge of the blank...there is a possibility of the blade exiting the wood as you are pushing the blank through the blade. Plan each cut, so you KNOW where your hands will be in the event of a slip. You cannot cut yourself if your left hand is behind the blade, a slip is usually harmless; the same slip with your hand approaching the blade could be a disaster.
Never cut with a dull blade. Your chances of being hurt are multiplied because greater force is needed to cut material. A slip or the blade exiting the cut is now much more dangerous. Hope this helps....btw, the bandsaw is a safe machine when used with a bit of care.
bob davis
>you will find a 3/8" 3tpi will work well for you
Don Pencil
Don Pencil
>Jim,
Keith Tompkins has it. You will not go wrong with this information.
I have used saws ranging from 14" to my current 24" Aggi. I have always used a 1/2" 3 or 4 tpi blade to cut circles. I would suggest that you try this blade before you go to anything small if possible. The smaller the blade the more flex the blade will have. As the blade will try to follow the wood grain on deeper cuts, thin can be a small problem at times.
Jim Driskell, head for the woodturning program at Cerritos Community College in Norwalk, CA. has 24 students on 24 lathes times 4 to 5 classes per semester. I supply the green wood for these classes and before that Jim did. We both use a 1/2" 3 tpi blade to cut the circles.
I might add that although many use a circle template to premark the circles before cutting, I and Jim do not.
I have learned that on a square block of wood a compass with a pencil in it does a great job. It allows me to set the circle to the exact size I want and get maximum use of my wood.
I also use a compass for marking natural edge blanks. This is a little tricky but with a little practice it works well. Instead of using the pencil tip to mark the wood I use a piece of chalk.
I position the point of the compass in the center. When I rotate it, I keep the compass level and mark the wood with the chalk.
I will post pictures for this later today.
Be Well,
Don Pencil
Carole Valentine
>I also use a compass. That way I am not limited to the sizes of templates I have. I use one of those giant, heavy-duty ones that in addition to holding a pencil it also has a scoring tip. I think the thing will do 36" or larger circles! LOL
Jack Savona
>Jim, I recently saw David Lancaster cutting bowl blanks on the bandsaw. Instead of cutting the full circle all at once, he started with the blade on the side parallel to the grain and only cut 1/4 of the circle in a clockwise fashion. He then rotated the wood 90 degrees and did the same. Next he positioned the wood on the OTHER side of the blade and did the same two cuts in a COUNTERclockwise fashion. By doing four separate cuts, he was always cutting WITH the grain and claimed it was easier and safer. I'll be cutting a blank later in the week and plan to try his method, assuming I have enough room with my saw.
problem with a compass
T Daniel
>If you use a compass you have to draw the circle on the flat side; then to see the line you have to turn the flat side up and the round side down. This puts you in great danger. When the wood rolls over (it will) it will kink the blade at best but at worst it will pull your hand into the blade. It is best to use the compass to draw a circle on a masonite board and saw that into a disc as described by others. You don't have to have a disc for every size; example: If you want a 10" circle take an 8" disc and saw 1" from the disc.
Don Pencil
Re: problem with a compass
Don Pencil
>This is how you mark the blanks using a compass.
Keep the compass level as you rotate it. Sight down the at the end of the compass and use a piece of chalk to mark the pattern.
Don Pencil
and when it's done
Don Pencil
>This is what it will look like when finished.
Just follow the dots with the bandsaw blade as you would a line.
There are days when I have to several dozen of these at a time and I really like the speed and accuracy of the method.
And note that the flat of the block is still on the bottom.
It works.
That works too...
T Daniel
>I used to do it that way to Don til I went to Maine. I figured that if those people up there knew how to grow crawfish that big they might know how to saw blanks out too so I have been doing it their way ever since. Of course this is about the only thing Mac ever taught me.....:)
Don Pencil
Horse Races
Don Pencil
>That's why they have horse races. Differences of opinion. ;)
Ya got to do what works for you.
Mike Schwing from Md.
>Terry, I use a compass almost exclusively, too, just as Carole. I mitigate the rolling situation you describe by cutting a flat surface parallel to the one I draw on when I'm cutting with a chainsaw. Each log has a smaller flat cut on both sides before I begin cutting out the pith. I then use the offcuts/cants to shore up the log. They are, of course, the perfect size, custom fit for each log! This does kind of lock you into a particular grain orientation, but it works well for most straight grained bowls.
Carole Valentine
>I only use that on slabs that are flat on both sides. I like Don's idea of the chalk for rounded pieces though.
SilentBD
>I use a jig to round my blanks on the bandsaw, it can be seen on my website at this address,
http://www.northwestturnings.com/boavt.html
Don Pencil
Don Pencil
>That is a great jig. Thanks for sharing it.
When cutting out rounds from green wood blanks that are 6"-12" deep (regardless of the diameter)the blade will tend to flow the grain and bend the blade. When guilding those deep blanks on a fixed jig it is not possible to adjust for the flex in the blade. The blade will bind or break. Handheld blanks can be adjusted as you move through the cut and the blade will be kept fairly straight.
A jig for large platters like the one you have on your web looks like a great one. I am going to add one like that to my jig inventory for the thinner platters and such.
Thanks again for sharing it. I think it is a wonderful idea.
Be Well,
Don Pencil
