Walnut Log
Walnut Log
Walnut Log
kgoring
>I have just come into a freshly cut walnut log about 10' by 12". What is the best way to process this wood for future turning blanks? Now if someone would just give me a lathe and some turning tools...
Re: Walnut Log
Just put it in the shade oof ground
T Daniel
Re: Walnut Log
Do I need to paint the ends?
K. Goring
Re: Walnut Log
wouldn't hurt.
T Daniel
>Walnut isn't too bad about cracking. You'll lose a little on the ends but since it is 10 ft long that shouldn't be a problem. direct sun will do more damage than anything else. The sapwood will rot but the heart will last a long time.
Re: Walnut Log
Re: Do I need to paint the ends?
Allen Neighbors
>TD's right. Paint the ends, and shade it, and if you can keep it off the ground, it'll keep a long time. I had one on the ground for over a year (this is dry country) and then raised it off the ground for two years, then started cutting it for bandsaw boxes. It keeps well. It would have kept even better, had I shaded it from the heat. I had enought left when I started turning that I got two bowls from it.
You are blessed.
AL
Re: Walnut Log
Brad Vietje
Re: wouldn't hurt.
Brad Vietje
>I agree that Walnut is quite stable, especially during the winter months. The only disadvantage of letting it sit around is that the sapwood won't be a real light color -- if you want that great contrast between heart- and sapwood in the future, grab some nice fresh stuff.
...now, about not having a lathe ... we gotta do something about that ... find the club nearest you (www.woodturner.org) and get some time on the lathe!
Safe Spinning,
Brad Vietje
Newbury, VT
