Motor questions...
Motor questions...
Motor questions...
DWR
>... I need to be educated... in plain english...;)
1. when converting from a manual pulley drive system to an electronic variable speed, and you have a choice between 1725rpm and 3500rpm three phase motors, what is the better choice? Why?
Since you are going to used an electronic variable speed controller, why would it matter what RPM you used?
2. Is it important that the motor is rated as Thermally Protected? Why/why not?
3. When a motor is denoted as having a .75 Efficiency Rating, does that mean that you will only get .75 of the actual rated HP?
Thanks...
Dave... "home schooling himself in the NW..."
Re: Motor questions...
Bill Howatt
>Are you running the motor/spindle directly or through a step pulley system? If it is direct and you want to turn at 3000 rpm then the answer is obvious. The better way of doing it is to have a step pulley system so you can always keep the motor rpm up at lower speeds for better torque. By letting the motor spin faster its fan will keep it cooler, if it turns too slow then you might need an auxillary fan blowing on it. They make motors rated for inverter duty which have higher temperature insulation. Either the 1725 or the 3450 motors have a little better torque but I can't remember which one. This also answers about thermal protection but I'd check to see if the inverter manufacturer had any concerns about it.
you should get the rated HP but the number shows how much more power you will have to feed the motor to get it.
Bill
