We value your privacy.
>Is anyone using SCM engraving tools for piercing or carving?If so which system would be best oil or none oil? What other manufactuers for this type of tool is recommended? What is a good price?
>I have a similar tool called a powercrafter. I have seen them for cheaper on ebay. You may want to make a search. I know the bits are cheaper at widget.com.and on ebay. I used to use mine quite a bit. Now I have turned to woodburning to embellish. For thin bowls/objects they work great for piercing. For thicker stuff or carving, a foredom or a dremel has a lot more power. For fine detailing they are ok.
>Hi, I have the SCM high speed engraver, it uses about a drop of oil every 6 to 8 hours of constant use. No big deal to put it in, after you do, hold it away from your work piece or hold it in a trash can and give a few bursts of air through it till no more oil mist comes out. Wipe off the nose of the piece and your ready to go. I like mine, great for detail work as the previous message noted. Don't let it stay idle for long, the oil will set up some and the turbine won't want to come up to full speed. There are cheaper units out there all depends on what your looking for. Also make friends with you dentist, mine uses a lot of diamond bits with very little wear for what I use them for and they are free! Take care, DonL
