A bowl sort of,
A bowl sort of,
A bowl sort of,
DougJ in Crawfordsville, IN
>Still having issues trying to make a conventional type bowl.
Re: A bowl sort of,
Re: A bowl sort of,
Barry Turner
>Looks like a perfectly acceptable bowl to me.......what kind of issues?
Re: A bowl sort of,
Dimensions
>2" tall, inner rim 8 1/2", outer rim 10 1/2", not sure of the wood type. Picture is not an actual color, more a banana yellow color. no finish as of yet. Here is a more acurate color pic.
Re: A bowl sort of,
Re: Dimensions
Jennifer@Indy.USA
>Hi Doug,
The bowl looks great. The first pic almost looked like cherry....but then on this second picture....and the fact that you say it looks yellow...I'm thinking it might be yew....or maybe osage?
Looks good to me!
Jennifer
Re: A bowl sort of,
Re: Dimensions
>Utilitarian or decorative? What I am asking is, what is the purpose of the rim/lip?
Re: A bowl sort of,
No purpose
>The rim has no purpose. It is what it is.
I will mount a blank on the lathe and start turning, whatever happens, happens. I never turn a piece with an idea in mind. The blank usually tells me what it wants to be.
Thanks for looking.
Re: A bowl sort of,
Re: A bowl sort of,
adrien
>stay unconventional. be creative. have fun. great bowl
Re: A bowl sort of,
Brad Vietje
Re: Dimensions
Brad Vietje
>Hey Doug,
That's a perfectly acceptable bowl there ! When you add a rim that the body of the bowl "passes through", it's most pleasing to the eye if the curve, seen from the side, looks like it passes through smoothly, almost like the rim was glued onto a finished bowl, and yours looks like it does -- this isn't real easy, and you did a good job.
My guess on the wood is Black Locust. While Osage Orange is pretty similar in almost every way, Black Locust looks yellow to greenish yellow (if log sat around a while) when new, and loses a little color to a slightly yellowish tan. An older log of Black Locust will usually show dark staining in the sapwood, too. My experience is that when turned fairly thin it it very stable, and very hard when dry. Osage will start out brighter yellow, and darken to a more coppery color with time.
Safe Spinning,
Brad Vietje
Newbury, VT
