35mm jaw choices
35mm jaw choices
35mm jaw choices
HeatherA in Anchorage, AK
>Hello All,
I was wanting to get a smaller set of jaws for a Nova Midi chuck (jet mini lathe) and was wondering about pros and cons of the 35mm bowl jaws vs. the 35mm spigot jaws. I am doing spindle stuff where I don't use the tailstock (little vases, tops etc.) and small bowls. Right now I am using alot of stock that doesn't fit in the 50mm jaws.
Thanks,
Heather
Re: 35mm jaw choices
Barry Turner
>For things like "little vases" where the work piece projects a bit from the chuck, I think you will get a better grip with the spigot jaws.
For something in a larger diameter like a bowl or platter, it's probably best to keep the work piece closer to the chuck with the standard jaws. I have the 45mm spigot jaws on my SuperNova and they work fine.
Thom in Kent,WA
>Don't know anything about the jaws question, but I wanted to say hi. I am a displaced Anchorage-ite living in WA. Just wanted to say hi. There is a company in Anchorage that make Birch bowls and sells them on the internet. I never did like turning Birch.
Brad Vietje
Brad Vietje
>Heather,
Great to respond to someone further north, and colder than me !
I have the 35mm spogot jaws and love 'em ! They are heavier than the 45mm, BTW, and very rugged. I use them mostly for tops, for which I have a good source of 1-5/8" dowels, and for small goblets. For larger diameter pieces the 45mm jaws might be better.
The new bowl jaws are very rugged, but fairly short, and not as well suited to taller goblet forms, though with a properly-shaped foot they will hold better than most people think, though the teeth on the spigot jaws are much better for gripping wet wood.
What do you have up there for hardwoods ? I know there are a lot of Birches in some areas of Alaska, but my impression is mostly softwoods -- any decent turning wood grow near you ?
Safe Spinning,
Brad Vietje
Newbury, in northern VT
Jorge Castaneda
>Heather,
I have the 45mmm spigot jaws, they have a lot more grip than the regular jaws, reccomended.
Jorge
>Hi Brad and Thom,
Alaska has birch, birch and more birch. The last president of our turning club calls it "crap birch" but he sure makes some beautiful stuff out of it! Birch burl is pretty. There is also alder, cottonwood, choke cherry and a few oranamentals like crabapple (and other apples) and ornamental purple leaf plum but they are scarce and you have to be in the right place at the right time. It kills me to see the pics of some of the trees you all get in the "lower 48". I am turning the 8/4 maple lumber that was going to be my wookbench until I got a lathe :)
Anyone with some time on their hands should come on up in March. Our turning club is having Eli Avisera, Jimmy Clewes and Stewart Batty up for a 2 day symposium. They are each teaching a intermediate and an advanced class but they are almost full.
Heather
