Have a question? Ask Woody!
Bench Grinder
Bench Grinder
Bench Grinder
>Hey everybody, it has been a while since I have posted or even turned. My life has been pretty busy this past few months with a new Son in the house (sleep will come soon I hope), and for me winter is busy with competitive curling. (gloat #2) I received a D. Ellsworth 5/8 bowl gouge for my birthday and am afraid to sharpen it. What I would like to know is I am considering buying the Delta Variable Speed Bench Grinder and was wondering if anybody had any precuations or suggestions.
Thanks Derek
Re: Bench Grinder
Re: Bench Grinder
John Veerkamp
>Derek,
You didn't say if you were looking at 6" or 8" grinders. From everything I'vem heard, the Delta VS grinders are not what the older model grinders were. For this reason I just bought the Delta 3/4 hp 8" industrial slow speed grinder. I understand that this model is being replaced by the vs grinder, but they are still available. I got mine from Amazon. I'm setting it up today with the wolverine system that I had on a 6" craftsman . The new grinder runs smooth out of the box and came with good wheels.
Good luck,
John
Re: Bench Grinder
Re: Bench Grinder
>Sorry you are correct. I intend to get the 8".
Re: Bench Grinder
Re: Bench Grinder
Sam Dean
>I have had the 8" VS grinder for about 3 years. A lot of people don't have a lot of good to say about this grinder, but mine's been great. It gets a lot of use and I've had no problems with it. I really like the VS feature and use it often for different tools.
Thanks,
Sam
Re: Bench Grinder
Its OK....
Peter Teubel
>The Delta "ShopMaster" VS 8" grinder is OK...once you replace the wheels and install a Oneway balancing system on it. I have one for traveling because its the lightest of the bunch.
Re: Bench Grinder
Re: Its OK....
>Peter thankyou for your input, what would you suggest as a permanent sharpening machine.
Re: Bench Grinder
Re: Its OK....
jared
>Buy the older Delta 8 inch slow speed grinder. I got mine from amazon a year ago but I guess they are still available. It is heavy and built like a tank. WHen you shut it off it coasts for ever it seems like. I am very happy with mine. Jared
Re: Bench Grinder
Couple Choices...
Peter Teubel
>The Delta 23-725 is a HEAVY, well built grinder. But you'll still need to buy a good wheel for it (comes with one 120 grit white wheel). The Woodcraft brand slow speed grinder comes with 2 good wheels (60 & 120 grit white wheels), but usually needs a Oneway balancing kit to make it run silky smooth. Economically speaking, the Woodcraft grinder with balancing kit is less expensive than the Delta 23-725 (more so when it goes on sale). I have 2 of those and have been using them daily for more than 4 years. No problems whatsoever.
Re: Bench Grinder
Re: Bench Grinder
Barry Turner
>I've got the Delta 8" Slo-speed grinder. Other than it's 90+ pounds, I can't think of an negatives. I have heard a few about the new VS Delta.
