Spindle>>>
Spindle>>>
Spindle>>>
Steve Woodall
>Hello all,
I am thinking of building a bowl lathe. I have nailed down all the pertinent parts except a spindle.
Any sources of spindles?
Any links to suppliers or machinists willing to make one at a decent price?
Are any of you machinists?
Thanks as always,
Steve
Re: Spindle>>>
Re: Spindle>>>
Gary in Zirconia, NC
>Might check with a manufacturer such as Oneway or Powermatic and purchase a repacement part for one of there lathes.
Re: Spindle>>>
Re: Spindle>>>
Sam Dean
>Hi Steve,
I've thought about the same thing myself for a long time. For shafts, any bearing supplier will carry them. If it is hardened, a machine shop may have to anneal the end before it can be machined. A hollow shaft would be ideal so you can use a vacuum chuck, but those may be a little harder to find.
I think the choice of bearings will be a little more important than the shaft type, and the seperation between the bearings on the head stock. To support the radial and axial loads from wood turning, a spherical roller bearing mounted in a pillow block would be best, but they're aweful expensive. A 2" spherical roller bearing from McMaster Carr is almost $210. If you don't use a spherical roller bearing, than some sort of thrust bearing would be necessary.
I guess you need to first determine how big you want to turn, then go backwards from there. Let me know how it goes, it may spark my interest again.
Thanks,
Sam
Re: Spindle>>>
Re: Spindle>>>
Garrett in Victoria
>I once saw plans for a shop-made bowl lather that used one of the FWD axle assemblies from a junked small car. It would handle just about anything.
Cheers, Garrett
Re: Spindle>>>
Try this link  *LINK*
Juergen
try this link
