Pen blanks?
Pen blanks?
Pen blanks?
AlienDude
>I was wondering, as I get ready to cut up some pen blanks for turning: Can one cut up a blank where the end grain runs length-wise rather than it being end grain on the ends? Would a pen hold up this way?
Re: Pen blanks?
Re: Pen blanks?
Norm
>I don't have an answer, but I would like to know as well, Also what is the minimum blank size for a 7mm pen? I assume 3/4" x 3/4" is best, but can .5 x .5 be done?
Thanks in advance
Norm
Re: Pen blanks?
Yes
Ron in Drums PA
>But it's tricky.
Make sure your tools are VERY sharp and go lightly.
Even your drill bit should be sharp to help prevent blow out. I little extra wood on the exit end helps.
Re: Pen blanks?
Re: Pen blanks?
Rick Davenport
>Yes, you can turn a pen on the end grain.
But it can blow up on you, depending on the wood type and how sharp your tools are.
I had some scrap osage orange and tried it.
The result was very nice.
This picture doesn't do the pens justice, but the one on the left is now my every day pen and my favorite so far.
Rick
Re: Pen blanks?
Re: Pen blanks?
AlienDude
>Yes, the pen on the left looks great! How about the pen on the right? How was that one cut? I think it also looks incredible!
Re: Pen blanks?
Re: Pen blanks?
Rick Davenport
>Both pens are end grain osage orange.
Re: Pen blanks?
Re: Pen blanks?
Ken Oakley-Sunny St. Cloud, Fla.
>I have been selling pen blanks on Ebay and had a fresh cut citrus orange log that I cut cross grain into 13/16th inch square by 6 inches and in 24 hours they had warped badly. Of course this was fresh wet wood. The grain was spectacular but I didn't want to sell warped pieces so they wound up in the trash. I guess if the wood is dry before cutting into squares it doesn't warp.
Re: Pen blanks?
Re: Pen blanks?
DWR
>Stabilized end-grain (cross cut) blanks hold up well but cost around $5.00 each+/- depending on species and quality... etc.
You can also have your own blanks stabilized and if you do any quantity turning, this is a viable option.
Re: Pen blanks?
Norm
Wayne Cooper in Charlotte
>Norm
If you can drill your hole perfectly in the center you can use 1/2 inch stock. 3/4 is much safer.
Wayne
Re: Pen blanks?
Try soaking in alcohol before drying.
Dave Smith, Longview, WA
>Hi Ken,
I have done some drying of pen blanks and other small turning pieces using alcohol. I have had fairly good results. There are a couple of things to consider when doing cross grain blanks. The smaller the growth rings, that is the closer to the pith, the more distortion you can expect. The easiest way to handle a lot of blanks after soaking in alcohol is to air dry for about an hour the put the lot into a paper bag for about 2 weeks. If you weigh and date a couple sample pieces in the bag you can track the progress of the drying.
One thing I tried that appeared to work is to stack the crosscut blanks end grain to end grain and clamp the stack so the end grain is not exposed to the air. Coating the end grain with wax helps also but it is time consuming.
For regular straight grain pen blanks just coat the end grain with wax and arrange them on a rack so all sides are exposed to air. My experience is that 5/8" square pen blanks will usually be dry in less than a week. Since the pieces are fairly small and the grain is not perfectly straight there will be some distortion of the blank. However, it usually does not prevent it from being used to make a pen.
Good luck.
Dave Smith
Off to collect a rear check from a craft store in Longview, WA.
Re: Pen blanks?
Re: Try soaking in alcohol before drying.
>Was going to try that but only alcohol I had was 140 proof moonshine so I drank it instead. The blanks straightened right out!!!
Re: Pen blanks?
Re: Pen blanks?
eaglesc
>Take a look at Russ Fairfields site,He explains the benifits of cutting blanks end or bias versus stright grained.
I don't buy precut blnks I would rather select the wood based on how I think the appearance will be as opposed to trusting someone who wants the most pieces from a piece of stack as oppossed to me wanting the best looking.
Bias cut red palm slimline with cherry burl CB
Re: Pen blanks?
Re: Cutting and Drying Pen blanks?
RussFairfield
>Eagle hit it right on. Commercial pen blanks are cut to get the most pieces out of a piece of wood. If you cut your own, you can do it the best figure. Even a piece of Ebony or Tulip that costs $60 a board foot isn't all that expensive when I can get 15 pen blanks out of it.
Any piece of wood that you can cut to 2-1/2" long and drill a hole through the middle is a good pen blank. We do it with antler and horn. Why should we expect wood to arrive in perfect squares?? The next time anyone has wood that has warped too much to sell, put a note here or on the www.penturners.org site, and you will find a lot of takers if it is a wood with a nice grain.
I use a Microwave drying method for pen blanks that is described in the following article. This was written about 5 years ago, but this is still how I dry pen blanks that were cut from wet wood. It would be worth trying on a few blanks cut from wood that is difficult to dry.
Microwaves and Pen Blanks
By Russ Fairfield (11-05-2000)
I use a lot of wood pieces that are either pen blank size or 2-1/2� square by 1� thickness. All need to be dry for turning. Because they are usually burl, wild grain, knots, etc. there is a lot of cracking during the drying and I was losing as much as 90% of the green Madrone and Myrtle burl and spalted Holly.
I gave up on boiling the wood. Beside the mess and time to boil the wood (1-hour in an open pot and �-hour in a pressure cooker), all of the color was leaching out of the wood, and the drying losses were only slightly less than that of un-boiled wood.
I figured that I would need more heat and less water, so I tried the microwave oven. Running Madrone and Myrtle burl on high for a sufficient time to get the internal water boiling out of the wood, then reducing the power level to hold that heat level until the water stops bubbling out of the wood (about 5 minutes), then letting it cool down in the oven, and then putting it into a vented box with a light bulb to maintain an 85-90F temperature until dry. My losses dropped to about 10%, with no loss in color.
This is totally contrary to the slow and easy approach to Micriwave drying that we would use on a bowl. The wood gets hot quickly and the water starts to boil out of the wood before there is any evaporation from the surface. 6 blanks arranged in a radial pattern on the rotating plate is the perfect load for the Microwave oven.
Added Note:
(My vented box is the old dishwasher described in Russ�s Corner here on Wood Central.)
After the microwave zap, the wood has done most all of its deformation, so from there on all it will do is to dry. Being burl, there are still some small shrinkage voids, but nothing that can�t be repaired.
This success prompted me to do some trials with pieces up to 3x3x6 (weed pot stock), and it didn�t work as well. The problem with the larger pieces is that the home Microwave oven doesn�t have sufficient power to get the water on the inside to boiling temperature without the wood starting to dry on the outside, and this is the perfect condition for cracking.
Re: Pen blanks?
Re: Pen blanks?
ScottS
>I've seen lots of 5/8" x 5/8" blanks for sale. Don't think I've ever seen 1/2" x 1/2" though...
Re: Pen blanks?
spalted holly?
>Russ,
I haven't seen spalted holly. Did you encourage the spalting or acquire it already spalted? Do you know if it spalts easily, like maple? I have a pile of holly that I'd love to try to spalt.
And thanks for the microwave info. (I don't remember seeing this article on Russ's Corner.) I've been using the low_and_slow method for thin spindle stock but never thought of trying brute force. I would have imagined the would would burn on the inside.
As for thicker stock drying too fast outside: have you tried again with a higher-power oven? (The last one I bought is far more powerful than earlier models) Also, I wonder if something like a cooking bag would let the interior water vaporize while keeping the outside of the wood wet. (Hey, one of these days I want to try boiling wood in oil - did you ever try that?)
