motor woes
motor woes
motor woes
Claudia Hayward
>I was merrily working away on my Nova 3000 (not DVR) on Sunday when I heard an ominous bang in my motor. To make a long sad story short, it turns out that the shaft of the motor snapped inside the motor. The motor shop that I took it to said that it snapped as cleanly as if it had been cut by a knife. This is a Leeson 1hp DC variable speed motor about 6 years old.
I'm wondering if anyone else has had this problem. I thought Leeson was a pretty good name in motors. Now I am looking at big bucks to repair or replace (sigh)
Thought I would phone customer service at Leeson but suspect it won't do me any good. Can anyone offer any advice? (sympathy also accepted!)
Thanks in advance....
Re: motor woes
Re: motor woes
Phil Joines
>Sorry you got shafted. It's a known problem with the Leeson motors on the 3000. They usually break between the end bell and the pully. I'd contact the people you bought it from and see if they will do something for you.
Re: motor woes
Re: motor woes
>I had it happen also but on a different brand motor. I think we decideded the problem is the design of the lathe. The pulley sits out on the shaft and there is considerable stress and flex on the shaft. The shaft can only flex so many thousand (or million) times before it fails. If this were only a leeson motor problem I would think that the motor was the problem but As I said mine was a different brand.
I put a bigger 3phase motor on the lathe with a Variable Freqency Drive. I had to have the shaft turned down to fit the pulley but a machinist friend did this for me. I used the lathe another year and then sold it to an upcoming professional turner. He has put countless hours on this thing with no problem so far.
Re: motor woes
Re: motor woes
Phil Joines
>John,
That is a lot of shaft hanging out there without support. Over tightening the belt makes for more flex. I had the Leeson 1 1/2HP VS motor and didn't have a problem in the 4 years I had it. From what I remember it was the 1HP that had the problem.
Re: motor woes
Steven Antonucci
Contact Tim Geist (Nova maintenance guy in WV)
steve antonucci
>As others have said, well documented issue, usually caused by too much belt tension on the motor shaft pulley. The warranty policy from Nova is pretty good, and even if you are out of warranty, Tim will do his best to help you out.
Steve
