Replace threaded insert on chuck??
DougJ in Crawfordsville, IN
>I need to replace the threaded insert on my Talon chuck. But the insert that is in the chuck won't come out, is there a magical trick to it? I have removed the three screws and nothing. I don't want to beat on the chuck and get it all out of balanced or anything, so any help is muchly appreciated.
Re: Replace threaded insert on chuck??
Charles Bjorgen
>Remove the three screws that attach the insert to the chuck body. Note the two holes that do not have screws in them. Take two of the screws and insert into these holes. Using the Oneway tool with the blue handle that comes with the Talon package, gradually tighten the screws alternating from one to the other. Net effect will be to press the insert away from the chuck body.
>Thanks Charles,,,, got it.
Now I can get this new PM running.
Jennifer@Indy.USA
>I'm glad I read this for if and when I need to do the same. I have a feeling I would have reached for Mr. Rubber mallet instead of doing it the proper way.
Thank you :)
Charles Bjorgen
>I did give you one bad piece of info though. The blue handled hex wrench supplied with the chuck only handles screws for removing and replacing jaws. You should also have in the chuck package a small 3mm hex wrench that works on the insert screws.
In the manual: Removing Adapter
Bill Howatt
