Thanks Keith (skew beads advice)
Ken Grunke from SW WI
>Just want to thank Keith Tompkins for the tip on turning small beads with the long point of the skew, in last Saturday's thread, "The hardest cut in wood turning".
Keith, I didn't get around to trying it until yesterday, but found it a lot easier than a rolling cut using the short point, for the small beads under say, 1/4" radius. I'm having a little trouble starting the cut at top center of the bead, to avoid a "corner". The skew has to be swung way over for this starting cut, at least for my skew with a long bevel.
I have a small round skew with a wider bevel angle and a shorter handle so I don't have to step back as far, but I want to get the hang of this cut with my regular flat skew and not have to reach for another tool.
Still working on it, just wanted to let you know your advice has not gone unheeded!
Re: Thanks Keith (skew beads advice)
Keith Tompkins
Keith Tompkins
>Thanks for the feedback, Ken. When I teach skew techniques, this is one of them. It works best when cutting above the tip, almost anywhere along the edge as long as the bevel is rubbing., and right on the centerline of the piece.
With a little practice, this technique works well for turning a sphere! It takes a little getting used to swinging the tool, but by bracing it against your side or hip, you gain incredible control...the "turner's sway". The cut is always visible from either side.
A detail gouge, on its side, flute @90 degrees to the rest, works very well this way. This way, rolling a bead from the left, then the right allows you to cut through to the center of the turning if you desire....there is no limiting factor to shape or design.
The neat thing about this technique is: you can work ANY diameter along the turning, without fiddling with the rest, and no rolling motion while raising the handle.
I'm working on an article on the subject..
Re: Scary stuff, you 2!
JamieDonaldson
Keith Tompkins
Keith Tompkins
>Hey Jamie....If you haven't tried this, give it a try, and let me know what you think! I would love to hear your results! Not as scary as it sounds....the scary part was the first time I tried it, as the technique contradicts most of what we read on the skew.
I can literally do the cut righty, lefty, and with my eyes closed, going by feel. Yes, I put a lot of time into practicing this.
Re: I have never done...
JamieDonaldson
>.... the taming of the skew! I do most of the little spindle turning that I do with either a side ground bowl gouge or modified spindle/detail gouge. I do use a skew on some long flat spindles, but sure don't consider it one of my favorite tools! I marvel at the skills of some of the European trained "skewmen" like Stuart Mortimer when I see them in action.
Question on blade edge angle
>Keith, as per Lacer's advice the edge angle of my skew is close to 90 degrees at the long point for a better peeling cut. Well, it's about 80 degrees. Then it angles back with a curve to the short point. Should I have a skew with more of an angle at the long point, for cutting beads this way? What's the edge angle on your skew?
I think this is why I'm having trouble with the entry cut. Could be my bevel is too long, also. Less than 35 degrees, bevel length almost twice the blade's thickness. Good for the rolling cut, using the short point however. Thanks.
Alan Lacer
Jorge Castaneda
>Ken,
i was at aa Alan Lacer demo recently, he said the skew shoud have a 20 degree slant and the with of the bevel should be 1.5 times the thickness of the skew.
here is a pic of Alan's own skew, he likes the radiused edge, I kind of prefer the straight one, but have to admit, he leaves perfect finish, no sanding needed.
Jorge
Re: Alan Lacer
>Jorge,
Good shot of Alan's skew. See how the edge at the long point is just about 90 degrees to the blade? That's what I'm asking about. Mine looks just about identical, I ground it that way after Lacer demoed for our club last spring. The curve made a big difference for me, much less catches when rounding over a curve using the short point.
But Keith's method of turning a bead with the long point seems to demand more of an angle there--see his post at:
http://www.woodcentral.com/cgi-bin/turning.pl?read=96066
Did Lacer show you how to make a hook tool? I thought that was great. That was actually Alan's second appearance for our club, he lives only about 4 hours north of us.
Hook tool
Jorge Castaneda
>Ken,
Yes Alan did show us how to make the hook rool, I thpught it was the best part of the demo, and it did work very well. I have made several since, a couple for myself and a number that gave away around christmas.
Lucky you that lives in the middle of everything, we are at the end of the road so very seldom we get a treat like that.
Keith Tompkins
Re: Alan Lacer
Keith Tompkins
>Hi Jorge, that photo looks good, I like the angle. However, I use a straight edge, no curve. I also hone my skews...makes a big difference, I think.
Keith Tompkins
Re: Question on blade edge angle
Keith Tompkins
>Hi Ken, I use a straight ground skew...I have tried a curved one and found no advantage. Rounding over the short end I feel is a disadvantage, as it's harder to get into a tight spot; the edge above it will contact a turning first, making the short end useless.
I would just experiment, seeing what approach works best for you. Remember, I don't cut with the long point itself, but the area above the point.
Re: Alan Lacer
Jorge Castaneda
>Hi Keith,
I like the straight edge myself, and lately I started to hone it too, I think you recommended that earkier, and Alan recommends it too, he uses a 600 grit diamond stone. I will be practicing your beading technique, Thanks!
Jorge
