Rotary Sanding
Rotary Sanding
Rotary Sanding
Doug Reynolds in Seattle
>Just got the Kilton rotary sander to use on smaller bowls as I have a mini-lathe. Richard Raffin, in a video, is using so much pressure he has to use two hands. How much pressure is appropriate to use on a small bowl mounted on a slow turning lathe? Also, do I apply pressure to the leading edge or the trailing edge of the spinning sandpaper?
Re: Rotary Sanding
Re: Rotary Sanding
Jack Savona
>I think that's the 3" black sander I'm using. Love it! As I recall Raffan uses his second hand for support. I often do too. As far as pressure goes, I find moderate pressure usually works well enough...if the paper still has bite. Don't hesitate to put on new paper if you find you're applying too much pressure.
BTY they now have 3" velcro backed MM which works beautifully with that sander.
Re: Rotary Sanding
Re: Rotary Sanding
>I prefer the trailing edge, less chance to dig in (and send the sandpaper flying off). "Moderate" pressure, for similar reasons.
