Bandsaw Wars: VICTORY!
Gary Evans Tallassee, TN
>Here is a pic of my "free" Delta bandsaw after what seems like months of effort to get it operational.
The 6" riser is custom made from 1" square tubing. The design was approved by an engineer buddy and he did the welding on it. It has a hickory sqare in each corner, two of which have holes for the alignment pins.
The motor is a 1HP Baldor which I got from Gary in Zirconia when I was in NC for the Statesville show. Thanks, Gary.
I still need to fabricate a safety guard for the left side of the blade, find some hexagonal stock for the upper guide assy, replace the blade thrust bearings and the tires. A better blade is also in the plan.
Right now, not counting my labor, I have $130 in the saw, including the cost of the blades.
Gary
Re: Bandsaw Wars: VICTORY!
Correction!
>I actually have $140 in the saw. I forgot about the big bolt that holds the top and bottom together, as well as the 5/16"x4 1/2" bolts that I had to buy to hold the saw to the base.
Sorry about that, 8^]
Gary
Re: Correction!
Gary in Zirconia, NC
>Gary, I been wondering how you were doing with it!! Wasn't that a 1 1/2 HP? Glad to see it.
Gary Bills
Re: Don't put off...
JamieDonaldson
>... adding that blade guard on the L side. That is a definite high risk area.
Re: Correction!
>I believe you are correct, Gary. I guess I'm in trouble now! A woodworker is supposed to be able to brag about the HP on his various tools. 8^]
Jamie, the blade guard is the very next project when I get back from FL. That's one reason I kind of tucked it behind the drill press. I have had all the contact with bandsaw blades that I ever want to have.
Thanks,
Gary
