Sending a picture
Sending a picture
Sending a picture
Blake Washburn
>I'm having a problem with sending a picture. The computer says that my picture is 662KB big. How can I fix that?
Re: Sending a picture
>Minimize the size. There are a bunch of free programs out there. IrfanView is one. "Shrink" the pic. Look at the FAQs #7. Mike has a very nice description of what to do there.
David Breth
>Somebody had a suggestion a few months ago that I have followed with success.
1) If you open the picture in "Paint" (Start/programs/accessories/paint), you can manipulate it prett easily.
Paint will argue with you at first that it isn't a BMP photo, but when you go to open the photo from a file, you can use the drop down box that shows up to select *.* (all file types), and your photo will show.
2) Save the file under a different name. I usually use the same file name, and same location where it already is, but put an "a" on the of the name, aka original image is "bowlphoto.mpg", and I save one called "bowlphotoa.mpg".
3) Now that you are dealing with a copy and won't ruin the original...look under "image/attributes", and you'll see the file size - presently something like 650KB. We'll be changing that - go to "Image/Stretch-skew". Change the two percentages in the same proportion. Example, make 100% and 100% into 70% and 70%. Close that window box, save the file. Look at image attributes again AFTER saving the file. Oh, now it is down to 400KB.
4) Repeat process until the file is the size you want.
There are probably easier methods out there, but for a computer-barely-literate guy like myself, I find this to be pretty quick.
David B.
