Where can I find
Ron in Drums PA
>I'm looking for a good source for tips as C and D in the picture below
I see tip like these in the turning catalogs but they seem high priced for a slice of HSS.
Where can I find
Ron in Drums PA
Re: Where can I find
Raymond Overman in SC
>//Announcer voice
Why Ron, you could try our new sponsor. Klingspor Woodworkers Shop carries just those type tips. I've seen them in the store just around the corner from where I work in Charlotte.
Mac
>Hi, These are really easy to make yourself if you have a grinder such as a 4" Makita angle grinder.All you need is some old planer or jointer blades,and a cut off wheel.Also it is easy to grind a slot in the edge of the cutters instead of drilling them,that way when you need to take them off to sharpen, you dont have to take the screw all the way out of the shaft.You just loosen it and slide the cutter off.One blade will make a lifetime supply of them.....take care....Mac
Will an old...
Terry Quiram, Roanoke Illinois
>skill saw blade work? I have plenty of those laying around and I need to make some scraper blades as well.
Terry
Re: Will an old...
Mac
>I think a saw blade is a bit too thin,might want to ask around at cabinet shops etc. to see if you can get a planer blade....
Scraper bits
Ray Thompson - Middletown,IN
>01 Flat stock, probably McMaster-Carr or MSC. Make em then heat treat em.
Ray
Re: Will an old...
Doug Trembath
>Terry, I've use a bunch of different materials in my search for the best finish possible. I've used sawblades as you suggest, and it will definitely work, but only as the cutting portion. I'd suggest you back it up with good quality washers with a smaller OD than the cutter, or a single backup piece of steel. If you can, as was suggested, plane blades will be a bit less prone to chatter, in my experience, but the saw blade stock will get plenty sharp.
Doug Trembath
Studio in the Woods
Re: Grade 8 flat washers are hard. They might work
Al Crandall (NE of Indy)
Looking for Flame box elder
ob obrien In Pensacola
>Ron; Go to the tool section at Sears. Look for moulding head cutter bits. There are three in a box and come in different shapes. They are HSS and can be ground to the shape you want. They already have a hole in them. I use the straight across flat ones and grind a teardrop shape out of them. Grind em at about 40 degrees. Hope this is a good inexpensive source for you.
OB
Where can I find
>Sorry the computer gremlins put the wrong subject title in the above message.
