Pyramid tool
Patrick Capobianco
>Can anyone tell me how to make a pyramid tool? I have all the material. Most importantly how to grind the bevels I have a Tormek and not a regular grinder.
Pyramid tool
Patrick Capobianco
Re: Pyramid tool
>patric I just took a hex nut that would fit over the rod I was using and drilled and tapped the side to take a set screw. Then I put this on the rod and ground each face with one side of the hex nut on my tool rest. I don't remember the angle, I would have to measure it.
What I did
steve antonucci
>I too own a Tormek, but rather than mess-up my wheel grinding the profile, I used a beltsander for the general shaping. I put a small cup of water to cool the tip, and ground three flat spots on the tip to form a point. Try to be symmetric, but I don't think it's terribly important.
Then, I used the plane and chisel honing guide to clamp the piece at a constant angle against the side of the wheel. I swing the honing guide up and down against the side of the wheel lightly to sharpen. After each side was sharpened, I stopped the wheel and registered the next side. The whole process took 15 minutes and the one I made works great.
Steve
Re: Pyramid tool
Dennis Y
>I did the same as John except I ground a flat on the shaft of the new tool to ensure repeatability of the grind. Dennis
Good idea. Headslapper kind
Re: What I did
Patrick Capobianco
>Steve, how did you keep a proper angle when you first used the belt sander?
