Face plate rings?
Face plate rings?
Face plate rings?
Carole in VA
>Do you guys use them? Are they secure? I ordered the one for 50mm jaws and they sent the one for 100mm jaws. I was going to return it but I realized it would fit my Powergrips so if there is nothing negative about the rings I think I will keep it.
Re: Face plate rings?
Mike Squire
>Carol,
I've had the one for the 50mm jaws for a while. It only has 4 screw holes but it seems very secure. I haven't had anything come loose yet.
Mike
Colin Spencer
>Carol, I have two one for 40mm jaws and the other for 100mm jaws. I use them all the time. I find it useful to just leave the chuck on the lathe at all times. A useful accessory for these is a disk tuned to the diameter of the centre of the ring (I used mdf)and then a screw through the centre of the disk (marked whilst on the lathe) just protruding through the bottom side. If you then put the disk with the tip of the screw in the centre of your blank the ring can be easily placed on the outside and screwed down. This means that it is always centred. My recommendation would be to stick with the ring.
Colin
Louis Bignami
>Ray Key uses 20 of these to gang turn plates. I've a half dozen of the 50mm and 100mm sizes. They work well now that I've added some holes. You might also like to look at some big metal rings. Drill some holes and the rings fit inside the jaws of several of my chucks.
Note: tough square drive screws are a must with the four hole models. I know of cases where rings screwed on with dry wall screws have sheared off.
