A55 Smoothing Plane
Willow - could not resist posting
David Breth
>My 21st bowl (I number them to see how I'm doing someday when I reach 100 and compare it to number 1, etc.). The guy across the street from me took down a willow tree, and I grabbed a hunk. At the time I only had a bow saw, and had to cut out the blank by hand. It was excruciating, so I only got one blank. But it was nice of the guy to cut down the tree and move it piece by piece from his back yard to the curb for me so I could make my selection.
I didn't have much hope for it at first, because a few people said they felt the willow was stringy to turn. I got the piece in May, and just turned it a few days ago. It was completely dry and stable, and turned unbelievably well. First pic is the lathe after the fact, with the bounty sitting next to it. Next post is the finished piece.
David B.
Re: Willow - could not resist posting
David Breth
>Here is the finished bowl. Minwax Antique Oil Finish. I think the Easily my favorite of the ones I've turned to date. I would greaty appreciate any critiques, however, because I do want to get better, but frankly, I'm just about busting because I like it so much and because it turned out to be such a great piece of wood to work with. I see willow at roadside all the time in the spring, so this won't be the last piece I turn. Don't worry about ruining my enjoyment of this bowl - because you can't - so blast away if you see areas for improvement!
David B.
Ad de Crom Netherlands
>Hi David.
I turned many objects from willow in the past, wish I had more willow.
This wood is perfect for turning bowls, I like the color of that wood. Even I turned a translucent lamp shade of willow.
BTW. your bowl is looking great!!
Ken Grunke from SW WI
>David, I love the grain of willow myself, and it's so easy and fun to turn especially when green. This piece has very nice grain, looks like some great chatoyance also. In my experience the wood is fairly weak, and sometimes develops ring shake, or cracks along the ring lines.
The inside of your bowl looks great--a good smooth curve, nicely finished. However, the outside doesn't seem to follow the inside's shape. It looks bigger, and seems to have a flat spot around the belly. Could be just the camera angle, though. It's a beauty!
David Breth
>It isn't so much a flat spot as it is a not-so-great continuation of the curve. Thanks for the point about the interior/exterior curving.
The subsequent bowl that I did to this was a cedar bowl, which had a sort of multi-curved exterior, and I did follow the curving design on the inside of the bowl. From a form standpoint, I think the new cedar one is a bit busy, but from a technical standpoint, I think it is a much improved bowl.
Thanks very much for the input!
David B.
