Micro Mesh question
Sean Troy
>Hey all, can you and if so how do you clean the micro mesh sanding pads. I have been using them dry. thank you, Sean
Micro Mesh question
Sean Troy
Re: Micro Mesh question
Jim Shaver - Oakville, Ontario
>Hi Sean,
I always use them wet....
I wash them in soapy dish water and then rinse them...let them dry.
I know I read about one person who puts them in the pockets of his jeans then tosses them in the laundry...
They sand really well and smoothly when used with water.
Take care,
Jim
Sean Troy
>You can even sand pens wet? How long before you can put a finish on the pen after sanding with wet micro mesh? Thanks for the help, Sean
>Hi Sean,
I use MM wet to sand stabilized woods and man made materials. Now when I say wet I don't mean dripping wet but wet enough to help keep the MM wet on the surface being sanded. I do place a shop towel in the ways under what I am sanding to avoid rust on my lathe.
On wood I some times use MM, wet on hard closed woods like cocobolo or rosewoods..but usually not unstabilized woods.
Others here may vary their use...I use MM on my pens...seems that is all I turn these days.
I first started using MM about 16 years ago, on model cars(another hobby!)..I used MM to rub out clear coat paint finishes...I had a hug smaile when I saw that pen and wood turners had a use for MM as well.... The sheets last a very long time for me, I have turned and finished about 100 pens on the set I am using now.
Take care,
Jim
Allen Neighbors
>Jim, I've never heard of micro-mesh before.... I've never seen it in any of the places I've ordered sandpaper... I've only been to one Woodcraft Store, so I might have missed it there. Tell me about it, please..
AL
>Hi Allen,
It's fine abrasive sanding product. It comes in grades from 1800-2400-3200-3600-4000-6000-8000-12000. I use it to refine a surface before my final top coat application, it is not a sanding paper. I know Rockler sells it and most hobby stores as well.
Take care,
Jim
Carole in VA
>Sean, I wash mine too. I just dip it in warm soapy water and brush it lightly with a soft bristle brush, rinse and let dry. Think I am going to try the jeans thing though. Wonder if it will hurt if I forget and put it through the dryer?
Allen Neighbors
>Thank you, Sir, for the information. After looking through the final finish on my last little vase ... closely ... I conclude that I need to sand a little longer, and finer. So I'll be looking for it the next time I go to a larger city. Thanks again.
AL
Sean Troy
>Thanks all for the help. I just did a cocobolo pen tonight and the 12000 put a nice shine on it.
eaglesc
>Klingspor now carries MM.
At least they did when I met the MM rep at the Klingspor fall extravaganza
