Good Lathe stand
Good Lathe stand
Good Lathe stand
Steve Woodall
>Hi All,
I recently bought a Jet 1236. It seems to be a great machine, but I am interested in beefing up the weight. I am not too impressed with the stamped steel frame and was thinking about building a cabinet from scratch.
Any input, opinions and especially PICS would be greatly appreciated.
Re: Good Lathe stand
Pete in Holland, MI
>Steve -
I built a plywood box to fit the area above the spreaders on the legs that is about 3" short of the bed. Had to remove the spreaders to install it, but it rests on the spreaders ("angle iron") Once in, the lid was removeable and it was filled with bags of small pea sized stone. Seems 130# went in. Box top is screwed in place. Make sure to use some peel & stick rubber at all contact points. Also mounted the feet on a couple 4x4's that are about 3" wider per side than the spread of the legs. Tie these together with a hardwood 1x6. Added some 1/2" thick 3" square pads to the bottoms of the 4x4's. This keeps the machine from scooting around the floor, but does allow it to wobble some with a big out of balance bowl blank.
