Benjamins Best Tools ???
MountainMan
>Anybody using the PennState Benjamins Best - China tools - HSS - tools?? The pictures in the catalog are purdy - I am wondering if they are good or ????
Regards
MountainMan
Re: Benjamins Best Tools ???
Bill Turpin in WNC mountains
>They are pretty good, especially considering the LOW price.
Bill in WNC mountains
GaryG in MD
>MountainMan,
Most of my tools are Crown and Henry Taylor. I have since obtained two Benjamin's Best HSS tools at very low prices -- in the $15 - $20 range. I'm just a beginner, but as far as I can tell, they work just as well as the others for which I paid 2 or 3 times more. This may not be the case for experienced turners (or maybe it is), but FWIW, they go like hot cakes at our club meetings.
I particularly like the 1" round-nose scraper (mainly because I didn't have one). This one has good weight and balance; it's very solid even though it isn't one of those extra-heavy ones. It cuts ribbons, and stays sharp at least as long as my others. I put a new hook on it 2 or 3 times with a burnisher between grindings. Works great.
I also got a 3/8" BB BG recently; I like it. Next meeting I'm going to buy the big BB BG so I can put a 45-degree nose on it, while keeping my old one at 65 degrees (for making the transition from wall to bottom).
Give one a try -- you have very little to lose and a lot to gain.
...Gary
Thanks
DougJ in Crawfordsville, IN
>I can't help to answer your question, but want to thank you for posting it. I didn't even know these tool exisisted. I think I'm going to give the 3/8" bowl gouge a try.
RussFairfield
>There is nothing wrong with them at all. I bought several of them for students to use on a 12" lathe. They are fine for that. The only difference that I can find is that the tool is sharter, the handles are shorter, and the scrapers a little thinner than some of the other tools; and that makes them ideal for a smaller lathe. The steel is an M2 high speed steel that behaves like a similar steel from Sorby. I think they are good tools if you want to save some money.
chris rolke
>also keep in mind that a 1/2" sorby is measured from the inside of the fluting and a benjamins best is measured from out side
( i ordered a BB from woodturningz and found this out if i were to order it again i would have ordered a 5/8" )
Scott Hurley in N. VA
>I've got a mix of Benjamin's Best, Sorby, and Crown Powder Metal (PM). From what I can tell, the Crown PM tools hold an edge better than the Sorby or Benjamin's Best. I'm very happy with Benjamin's Best. Like any tools, just keep your grinder close to the lathe!
Scott
