Salad Bowl Thickness
Doug Reynolds in Seattle
>I am making my first sets of salad bowls. Wood is elm and walnut. What is a good wall thickness to aim for? Bowls are 6 inches in diameter by about 2 1/2 inches tall.
Re: Salad Bowl Thickness
John Veerkamp
>Elm and Walnut can both be turned fairly thin. In that size for a salad bowl I would go for about 3/16 to 1/4.
John
GaryG in MD
>Just my opinion, FWIW: for a 6" bowl (which I consider on the small side, relatively speaking), if the wood is sound, I'd try for 1/8". I've had good luck with walnut at 1/8" -- they're plenty strong for that size and weight. I'd be comfortable with 1/8" up to about 8" in diameter. ...Gary
Dennis Daudelin
>I find that people buying my salad bowls prefer the thicker wall ones than the thinner walled ones. They also like the extra weight of a bowl that is thicker. I like to turn them thin but the feedback is that they are afraid of what will happen if they drop it. So, they buy the thicker walled ones!
In the 6" range, 1/8" inch is fine but lots of people like the 3/16" better. And in the 8" range, 3/16" is fine but lots of people like the 1/4".
And in the larger sizes at least 1/4" is minimum for me to sell them.
Hope that helps,
Dennis
RussFairfield
>The thickness can be almost anything you want it to be. Just as with the shape, it depends on who you are trying to please, and the wood it is made from.
If you are trying to please other woodturners, they love thin walled bowls. The problem is that they don't buy any bowls.
If you are trying to please someone who will use the bowl, then it has to be "useable". That means it has to stay put on the table while it is being used, and it follows that the walls should be thicker because the bowl will be heavier.
If you are trying to please someone who will place it on the mantel to look at, the outside shape and the wood itself are more important than the wall thickness. The thickness could be a compromise between being thin enough to display our skill as a woodturner, and thick enough that it isn't fragile. Or it could be very thick to show off a natural edge, burl, or some other part of the wood, and that could be very thick.
If you are selling the bowls, you need to be making thin, thick, thicker, and everything in between, because you can't predict what people want in a bowl.
