REAL MILK PAINT
Turning Oak Burl
Turning Oak Burl
Turning Oak Burl
Niedling
>I recieved a 4" x 8" square oak burl which has been sealed with anchorseal. I have never turned a green burl, so whats the best way 1) turn it to a finished piece or 2.) rough turn it & allow to dry & then finish turn it?
Re: Turning Oak Burl
John Veerkamp
>Burls don't usually distort much so turning to finished thickness works well. Be advised that wet oak smells like cat urine when turned. I just turned two pieces this weekend and LOML just about threw me and the lathe out the door. Cleaned up the shavings and turned some cedar to deoderize. It seemed to help. Good luck.
John
David Breth
>Oak is pretty inflexible stuff. Green oak will warp after you turn it, and the wood won't move well to support the drying/warping without cracking if the walls are too thick.
David B.
Molly Winton
>I've just finished turning some oak burl, and it was very green. Luckily I had a good odor, not cat pee. Mine smelled like fermenting wine. The smell you notice when walking into a winery where the wine is aging in oak casks. I turned mine to final thickness, about 3/16" with resulting negligible distortion. The surface rippled a little, but I really like the effect that gives.
I've attached the two pieces I've recently finished to show you. The one on the left I just took sitting here at my desk, so it not the best picture quality. It is still drying, so has no finish on it as yet. The one on the right has a Danish oil and wax finish.
The wood was very easy to turn. I think it being green helped a lot. Dry oak can be a bear to turn.
Re: Turning Oak Burl *LINK*
Ralph Tursini
>I think the matter of finish turning green or twice turning is more a matter of preference and style that one way being better than another.
Last year I turned several bowls from a large red oak burl. I like the texture and ripple provided by the drying wood so I turned and sanded the pieces while green.
The burl had a large wavelength curl to its grain which radiated out from the center of the burl. It also had smaller areas of tightly swirling grain. The resulting texture was interestingly tactile and pleasing.
I think that it is easier and faster to dry a piece which has been finish-turned while green because it doesn't have to be left so thick as with the twice turning method. The stress of the wood movement in a thinner bowl is more easily relieved when warping.
The downside is the higher stakes. You lose more of your invested work should it crack while drying!
Have fun with it
Ralph Tursini
Tursini Woodturning and Bowl Works
www.vermontwoodturning.com
Link to photos of the other oak burl bowls
Thanks for everyone's input
Niedling
>Thanks for the input.
