Re: Delta Lathe motor size
Frederick Nelson
>This is about the best I have at the moment. It shows my tool rack (that normally hooks between the stand and the lathe bed) better than the ballast box. I'll see if I can get a better shot later today.
Beneath the lathe stand is a square frame that raises the lathe 3-1/2 inches, bringing the spindle height up to a more comfortable (for me) level. This is just four 4x4's bolted together, with a 3/8" recess on top for each foot, and a 3/8" pad beneath each foot to make up for the recess.
The box is simply half-inch plywood, with 1x2 reinforcements at the inside corners. The box is a truncated pyramid fitted into the space above the stretchers and beneath the top of the stand. The inside seams are sealed with silicone caulk to help contain the 185 pounds of loose sand inside. To get the sand inside, there are two loosely fitting lids on the top surface resting on their openings. I had originally intended to use t-shaped toggles wedged between each lid and the top of the stand, but I find gravity works just fine for keeping the lids closed. In the event I have to move the assemblage, (more like a "when" than an "if") there is a drain hole at one end, allowing the sand to drain into a bucket or two. The drain hole is reinforced with a second layer of plywood in that location only, and fitted with a gravity held plug (turned, of course,) to keep the sand inside. All this is probably much more elaborate than it really needs to be. I have Swedish engineers on one side of my family, and German engineers on the other - it shows up from time to time.
If I were doing it again, I would do something like Dominic Greco did with his Jet 1642, suspending a simple box between the spreaders, and using bagged sand instead of loose sand. See Dominic's article in "WC Articles & Reviews" for inspiration. Its complicated design notwithstanding, the setup is remarkably resistant to vibration, and if I stand on the base frame and use my considerable weight to try and tip it, it doesn't move. (Unfortunately, I can't move it easily, either - we just had a new washer and dryer moved in and, naturally, they had to go by the lathe.)
Drop me an email if you'd like to see some other pictures of the assemblage, and perhaps some details of its construction.
FNelson
