Problem Solving with the Bowl Gouge..
Wally Dickerman in Arizona
>It seems that many turners have a problem with tear-out and rough surfaces when hollowing a bowl. Mostly in the transition area between the sides and bottom. There is a cut that many turners aren't aware of that solves the problem.
This method is especially helpful when hollowing in a fairly deep bowl. It's used where the rim gets in the way when trying to approach and cut across the bottom while rubbing the bevel. My solution: While you're cutting down the side, swinging the handle toward you, when you reach that transition area, roll the tool slightly so that the flute is facing up a bit more, with the bevel still on the wood, drop the handle and push the handle away from you. Cut in a rainbow arc to the center of the bowl. You'll ride the bevel all the way to the center in a very smooth, controlled cut. You'll be cutting near the nose of the tool. When, and how much you roll the tool depends on the grind you have on your gouge.
This is a very easy cut to master and use. Just takes a little experimenting and practice. The only danger here is, with the flute up, if you let the bevel get away from the wood a dig-in is possible. I can't remember ever doing that however.
Wally
Re: Problem Solving with the Bowl Gouge..
NotsoDull!
>Thanks for the tip.
I've just printed the description of your technique and am going to try it on my next bowl.
It may prevent me from having to change my middle name to Tearout.
Rick
I just did the same thing
Wolf Kiessling
Re: I just did the same thing
NotsoDull!
>You changed your middle name to Tearout???????
>Wally You described it well. I remember distinctly when I discovered that I could roll the gouge and still stay on the bevel. Up to that point I think I was scraping across the bowl to the bottom. It was quite a revelation for me. If they follow your advice there will be plenty of happy people out there.
Dave Hout's idea from DIY Woodturning. Comments?
Craig Daymon
>I watched David Hout on DIY Woodturning today (Tivo'ed from yesterday) and the project was a lidded container with a very deep bowl like profile. (Although, not as large as most bowls might be.)
When he got to the bottom, he pulled out what he said was his secret weapon (or some such). It was a ball end mill fixed on the end of a hollowing tooll shaft. He starts in the center and rolls it a bit as he comes toward the transition area. Sorry, I'll have to watch again to give a better description, but sounded interesting considering the spiral nature of the cutters on an end mill and its application in turning.
-Craig
GaryG in MD
>Thanks Wally,
There are a lot of relative beginners on WC, and I think you're doing a great service by posting technique tips like this.
I too printed it out for future reference.
It's a great idea, and I hope we see more of this kind of post from our very experienced turners in the future.
Gary
Re: Dave Hout's idea from DIY Woodturning. Comment
Greg in Oshkosh
>Dave Hout's covered bowl was endgrain not sidegrain. Scrapers work well on endgrain. On sidegrain they tend to tear out some sections and need to be used as shear scrapers or they can make the bottom rougher than a gouge leaves it.
Ball End Mill - Scraper?
Craig Daymon
>So you would consider the ball end mill to be a scaper? I would think it is almost like a spiral gouge, though what that means to turning I don't know.
-Craig
