REAL MILK PAINT
need help, Milwaukee close quarter drill
T Daniel
>I just took apart my drill to make photos of the steps in replacing the bearing. This drill had been dropped and would no longer run so I ordered a new switch along with the bearings. This is the new style switch with the fwd/rev on top. Anyone know how to release the old wires? It appears the wires can be pushed in but not pulled back out. Anyone been here before?
TD
PS, I will have pics of the bearing replacement shortly.
Re: need help, Milwaukee close quarter drill
Jorge Castaneda
>Terry,
Many electrical connectors are that way, they go in and a srrated thing does not let them out, is it possible to cut the wire , peel of enough insulator and shove them in to the new switch?
just an idea.
Jorge
Phil Joines
>Some connectors have a tab in the center that locks into a recess. If you can see it a curved dental pick can be used to release pull it up.
dental pick worked
T Daniel
>now the switch is wired in so all I got to do is get all the pieces back where they go and find a place for the wires; fun day next to the stove.
Thanks all
TD
yesterday I couldn't even spell xpurt.....
T Daniel
>today I are one! I finally have my Milwaukee close quarter drill back together and running. That switch is a bear to put in, much harder than the bearing. Those wires have to be exactly in place or the cover will not go back on. The bearings I will continue to replace but the next switch that goes bad will be replaced by a Milwaukee service center. It was just too much fun for one day!
Thanks to those who offered suggestions on getting the wires out of the old switch.
I have taken pictures of the entire process and will get them to Garrett so we can archive it.
TD
Darryl Hansen
>Terry, I have the wiring diagram and instructions (as limited as they could make them). They are in Bulletin 58-01-0372 which I probably got from Milwaukee maybe on their web page don't remember. If they would help I maght be able to scan them and send as an attachment to an e-mail...Darryl
Thanks Darryl, we'll put it into a library.
T Daniel
>Either mail or email it to me and I'll get it to Garrett and we'll make a libray on the repair of these drill we all use. Mine is back in service but a few tips going in would have saved me a couple of hours work. Let me know if you need my snailmail address.
TD
