Re: This may help
RussFairfield
>I wrote an article about turning a square bowl for the AAW Journal a long time ago. This is an exerpt of the safety part of that article. There is a photo of the bowl from the article at the end. I apologize for the photo.
Turning the wings involves an interrupted cut that becomes nearly invisible at their tips � the �ghost�.
SAFETY RULES --- Again!
Safety Rules are published and promoted by the AAW to make the lathe a safer place for all turning activities. All of these rules are especially important when turning a large �square�. From personal experience, the following four are critical:
1.
Be alert at all times. Know what you are doing and where you are going with every movement. Know where the �ghost�, tool, hands, arms, face, and body are, and their relative locations at all times.
2.
Always rotate the work by hand BEFORE running the lathe, and NEVER move the tool rest while the lathe is running. No further explanations are needed.
3.
Always wear a full face shield. It is far better to hit the mask than your nose when we forget Rule #1. Also, sharp splinters can be broken away from the wood at the corners.
4.
Relocate the START/STOP switch so that it can be reached without passing either hand or arm near the �ghost�. The switch on most lathes is not in a safe location. If you don�t want to move it, or install a remote STOP, you have been warned!! I have had two encounters with the �ghost�, the first while reaching for the OFF button, the second the ON button. Then I moved the switch.
The Lighting
Visibility is as important as a sharp tool and safe working habits for turning on the �ghost�. A 100-watt clear incandescent bulb with a reflector is ideal. More light than that and the background becomes illuminated through the �ghost�. Many turners have advocated placing sighting boards behind and opposite the turning to enhance the �ghost�. I have found them to be a poor substitute for a bright light shining on the working area. The sighting board only provides a uniform background, while the bright light accents the surface of the �ghost�. Both might be necessary in a brightly lit shop (I don�t have that problem).
