Carving letters on turned items
Peter Charles Fagg (UK)
>I have been asked to cut the name of a child and its date of birth onto the flat face of a platter. I am no mathematician and every time I roughly pencil on the letters it either looks terrible or is unequally spaced or just looks downright rubbish! Does anyone know the secret OR is there possibly some software that can be employed to give me the correct dimensions etc? Please remember I am not a mathematician, I can speak 3 languages but this calculation stuff is really beyond my comprehension. Regards Peter.
Re: Carving letters on turned items
>I forgot to add that I have conducted a search on both the "Turning" and "Woodcarving" messageboards to no avail. Regards Peter.
Barbara Gill, Remlik VA
>Unless hand carving is the only way the customer will allow, you might consider having it laser engraved. I had some pens engraved for nieces and nephews one Christmas.
>Charles Find a type face you like on Word and size the letters on that. Then when you get it you can trace it from the page onto the wood, or you can glue the paper down and carve or burn through the wood. I use 3M super 75 positionable spray adhesive. If you have a way to reverse the type on the computer (I do it in Photoshop but Tshirt printing software works also) you can copy the image on a copier and then iron the copy onto the wood. You can also brush Naptha onto the paper and the copy image will come off on the wood.
>John, thanks for your reply. Only one thing that botthers me is that as the letters are viewed around the edge, the outer edge is stretched and the inner compressed so that they appear to be part of the whole but IF (a big if) I use them straight as per your suggestion, are they not precisely square and therefore not (contoured?) to the circular platter? (please excuse my ignorance) Peter.
>Barbara, thanks for the idea. The customer is expecting it to be hand carved and I expect that laser engraving would be cost prohibitive, even if I could find someone within easy reach on the island. Regards Peter.
>I'll get this right one day! I forgot to include that the platter is 14" inches in diameter with a 1.1/2" inch width flat around the edge. Apologies.
Stuart Johnson
>Try Wordart tool bar in Word. You might need to play around to get the right size but I think it might work.
John U - Charlotte, NC
>Peter - if you tell me what size lettering, what font, and whether you want the name oriented facing the outside rim or center of the platter, I can send you a template. The attached drawing is an example using 1" letters with a 1/4" offset from either edge of your 1.5" rim. Email me privately if you are interested.
John
I can do it on CAD if you want.
Dave Smith, Longview, WA
Mike Swain
>Hello Peter,
Do what I do, call round at your local sign shop with all the dimensions, choose from hundreds of different fonts and they will either cut you a sticker to draw round or print the drawing out on paper to trace onto the plate.
I get a sticker and it costs me less than �1.
Mike Swain RPT
>Stuart, thankyou for the suggestion I will certainly attempt to use it. Peter
>Hello again Mike, thanks for the response. If only there were a local sign shop! The only signmaker willing to discuss such things with me is a dyed in the wool wood carver who wasn't willing to impart any knowledge, probably because of fear in losing business! Good thought though, if this sort of item is needed again I will have to seriously consider taking a course at night school! Peter.
>Thanks John, email despatched.
