Sumac Trumpet Vase
Sumac Trumpet Vase
Sumac Trumpet Vase
Ken Grunke from SW WI
>This is my submission to the Contemporary American Woodturning exhibit at the Rochester Art Center, in Minnesota.
I've been putzing with this all day, trying to finalize the finish and looking at it with a very critical eye. But not critical enough--earlier in the day, I buffed the interior and found sanding scratches I missed earlier. So, back to resanding and refinishing. The wipe-on minwax polyurethane was dry enough by early evening to give the final polish, and I'm now out of elbow grease.
If you saw my post last night about thinning wipe-on poly, this is the piece in question.
I didn't try thinning it, didn't have naptha as Mark Mandell suggested.
My solution was to level the streaks with 1200 grit wet n dry abrasive, right down to the wood--but not into it. Then I buffed the exterior with white compound on a muslin wheel. I had to do the inside by hand, therefore the dry elbows--don't yet have a small buffing head.
Still not happy with the surface in some places, but it will have to do. For the most part, it has a nice semi-gloss finish.
It's is Smooth Sumac, 8 1/2" high and 4" across the top. I was amazed at how the bark stayed intact, given that it's summer-cut wood. The turning was centered on the pith, which itself is off center giving the interesting shape to the rim. It's a dry vase only, won't hold water but future ones will have an epoxy finish.
All comments are welcome, thanks for looking!
Re: Sumac Trumpet Vase
GaryG in MD
>Ken,
Looks good enough to eat. ... no; wrong comment ...not an ice cream cone. ;-)
I mean it's Beautiful! I love the shape and the rim and the grain and the whole nine yards. Very impressive.
Good luck with your submission,
Gary
Ad de Crom Netherlands
>Ken, very elegant vase.
I like it a lot
Did you the hollowing right trough till the foot?
Carles, in Barcelona
>Very nice. I like it.
Un saludo,
Carles.
Ruth Niles
>Hi Ken,
This is a beautiful piece, very pleasing form. I'm surprised the bark stayed on, too, it definitely adds to the piece.
How does "smooth sumac" differ from staghorn sumac? Sumac is my favorite wood to turn and I've found the more you sand, the more sanding marks are in the wood. I can't start with anything rougher than 220 on sumac since it's such a soft wood and can only use very light pressure when sanding. Do you do a lot with sumac and do you find this to be true?
Ruth
RussFairfield
>Ruth,
The difference between Smooth and Staghorn Sumac is in the bark. One is "smooth" and the other is "fuzzy". "Staghorn Sumac" is also called "Velvet Sumac". Other than that, the wood is the same if the two grew in the same place.
There are at least 50 sub-species of Sumac in North America, if my memory is still working, so there are always regional differences in both the wood and the name.
Bob Slocum
>I don't like the sumac pieces I've done, but this piece works!!
