Re: Turning exchange item arrived...
Juergen
>Ronny glad to hear it crossed the pond in one piece and that you are enjoying the turning. Thank you for displaying it so nicely in your pictures. When I was photographing the bowl for my records I found it hard to capture all the facets of this piece. I started out with a 2 branch crotch, the interesting thing is the trunk and the branches were similar in diameter giving the piece unusual symmetry. The blank had a very nice crotch flame, but I lost some of it in order to maximize depth of the bowl.
The finish is as simple as it gets. Sand to 600 grit using an air powered random orbital sander. I can't say enough good things about this tool, it has raised my finishing to the next level. Liberally apply (soak) the turning with WATCO Danish Oil (natural) until it no longer absorbs the finish (no dull spots), finally wipe off excess and let dry thoroughly. Buff, apply a thin coat of WATCO, wipe excess, let dry, buff or steel wool lightly and wax with a Microcrystaline based wax (no fingerprint) I buff the wax with a small piece of sheepskin to which I've glued some velcro. The skin can now be attached to a power sanding disk for buffing. This piece required only two applications of WATCO.
I started using this technique about 6 months after I started turning, when I discovered I liked finishing as little as sanding.
