Cedar Elm Closed Form
Ric Taylor
Ric Taylor
>This is a Cedar Elm crotch closed form that I completed quite awhile ago. It's 11" x 3 1/2". The wall thickness is about 1/8" except around the opening where it flares a little thicker.
I was interested in this piece of wood because it contained heartwood and sapwood, good "perfect" wood and rotted wood, and large worm holes and tiny worm holes all in one piece of wood, providing a lot of character. Working around the rotted wood area was quite a challenge.
The finish is many many coats of wipe on poly. Comments are welcome.
Ric
Re: Cedar Elm Closed Form
>Ric Very good job on the photography. I love what you did with the lip. The rotten areas make such a great line through the piece.
A work of art!
Mike Schwing from Md.
>On both the part of Mother Nature and the turner. Congrats Ric, that is a superb piece of woodturning! I like everything about it.
georgetroy
>Very good job. Nicely done. You got the most out of it. GT
NotsoDull!
>Absolutely spectacular.
How did you get such a fine finish on the inconsistent surface?
GaryG in MD
>To my eye, that's museum-grade work. Truly lovely. Now if you could just train those worms... ...Gary
Wow! Fantastic
Ed Kelle
Ric Taylor
Ric Taylor
>Thanks, John. I forgot to mention that it was my second attempt at hollow turning.
Ric
Ric Taylor
Re: A work of art!
Ric Taylor
>Mike,
I appreciate your comments.
Ric
David Breth
>That piece is ridiculously impressive. You say you've been turning for six months? Not bad. Can't wait unti you get good at it.
But in the meantime, keep praciticing. The results are pleasing.
David B.
Ric Taylor
Ric Taylor
>Thanks for your comment.
The finish was a result of a great deal of frustration and MANY hours of work. There are more than 20 coats of Minwax wipe-on poly, applied delicately, each time hoping for a smooth coat. I never could get it to dry smoothly, always there were streaks, so I would wet sand with 600 grit and mineral spirits, then try again with another coat.
While I was fighting this process, I purchased the Beale buffing system, which I had never used before. Using tripoli and white diamond, the streaks polished right out. It was pretty sporty working around the delicate openings, especially in the rotted area, but with a light touch I had it done in about 30 minutes. This was after struggling with the project for more than two months.
The wipe-on poly helped a lot to stabilize the rotted section.
Ric
Ric Taylor
Ric Taylor
>Thanks David.
I didn't say I've been turning for six months, that must be someone else. When I did this piece, I had been turning a little less than four years, but it was my second attempt at a hollow turning.
Ric
Terry Quiram, Roanoke Illinois
>WOW what a great piece. Beall buffed??????????? Talk about being brave. Outstanding photo.
Terry
RevDoug
>Super piece, Ric. The wood is georgeous. Your work is very good. An excellent combonation.
Turn 'em round,
Ric Taylor
Ric Taylor
>Since it was the first time I used the Beale system, I think it was a case of "I didn't know I shouldn't do it," and I got lucky. Ignorance is bliss sometimes.
Ric
Ric Taylor
Ric Taylor
>Many thanks.
Ric
Ric Taylor
Ric Taylor
>hmmmm........ I'm listing ways to motivate a worm.....
