Re: Dang it! That hurt!
Matt Birchfield
>With your elbow tucked in, touching your body the arm brace is a safe tool.
I do my large turning on an old Oliver 20C which has a 5HP motor and 4" flat belt drive. I've had a catch or two using the arm brace while extended a long way out over the tool rest... any one of them would have caused serious injury to my shoulder if I hadn't had my elbow tuching my side.
Because I use safe technique the only injury I suffered was because my head bumped the low rafter I was standing under (I'm 5'10" tall and the rafters in my basement shop are about 1/2" to 3/4" higher). Needless to say this is a laugh-getter when I demonstrate for clubs.
Even with the worst of catches on a 5HP lathe with a very positive motor drive system (the big flat belt) the belt did slip and my arm and shoulder were not hurt.
IMPORTANT: The arm brace fits my arm very well and I weigh over 200 pounds. A smaller person with a poorly fitting arm brace may have problems with a smaller lathe regardless of technique. I am also very comfortable with what my tools are doing at all times because I have used them for a long time every conceivable way (at least every way I can think of).
Matt
