Oneway Talon Set Screw *LINK*
Craig Daymon
>I want to order up some soft tip set screws for my Talon chuck. I know it is an 8mm set screw, but McMaster-Carr has many additional qualifiers such as length, metric thread pitch, thread size (M8?), so does anyone have a good sense of what I should use/select?
Link to the soft tip page where I stopped qualifying below. Hopefully it will take you there as I think some of their page is dynamically construct.
Thanks,
Craig
McMaster-Carr Set Screws - Nylon Soft Tip
Re: Oneway Talon Set Screw *LINK*
The link won't get you there...
Craig Daymon
>...if you are interested, try the main page, http://www.mcmaster.com , and do a search (find) on "8mm set screw". That's where I started.
-Craig
best to post this question on ... *LINK*
e
>the oneway forum ... oneway is great at responding back ..
http://www.oneway.on.ca/forum/index.php
Bill Howatt
>I went to a fastener store and bought a M8 setscrew that had a coarse looking thread. Was the one they had in stock (which probably means it is the most common size) and it fit. Looking at it, I'd say it is 1.25 mm pitch but I'm not sure. A 1cm long screw would do. If it sticks out a bit it doesn't matter because it is shielded by the chuck so you wouldn't catch your fingers on it. You could probably use a shorter one as well.
If you get an answer from the Oneway forum as suggested by the other poster, plse post the info in this thread. This question, or a form of it, comes up from time to time. I don't know why Oneway doesn't include the spec in their documentation.
Bill
yes 1.25 pitch
Ed Kelle
>I measured up the ones I have here. Where did I get them? With the oneway 3" faceplates I have. Two with each one. For a $200 chuck I'd think they would give you a pair. Or at least tell you what size. I went thru the book a few times until yesterday when cleaning up my chucks, I saw the small bags of setscrews and tried them, perfect fit. And they use the same allen key as the jaw bolts
Re: yes 1.25 pitch
Craig Daymon
>One of the other things I'd like to get to use with the set screws is a proper size hex T-wrench. I'm doubtful, but I'll stop by HD tonight.
-Craig
You have it!
Bill Howatt
>The 4mm T wrench you got with your chuck to change the jaws fits M8.
Bill
Perfect! Thanks. Here's the screw description.
Craig Daymon
>I tried following the posted link to the OneWay forum, but couldn't get there. Still, I know what screw I need and I'm ordering them from McMaster-Carr tonight...though I do have trouble ordering such a small package from them. (Hope shipping doesn't kill me.)
Here's the info:
Part Number: 94085A141 $6.08 per Pack of 5
ANSI Specification ANSI B18.3.6M
ASME Specification ASME B18.3.6M
Screw Style Standard Socket
Material Type Steel
Finish Black-Finish
Tip Material Brass
Point Soft Tip
Point Diameter 4.8 mm
Point Length 2.4 mm
Hex Key Size 4 mm
System of Measurement Metric
Thread Size M8
Length 10 mm
Metric Thread Pitch 1.25 mm
Thread Fit Class 6g
Specifications Met ANSI and ASME
Rockwell Hardness C45 for the screw
B55 for the tip
Note: Length listed for soft tip set screws does not include the tip. Tip length is 2.4 mm.
-Craig
P.S. They also have Nylon tip set screws fitting pretty much the same description (other lengths and sizes as well) for about $10 for 10. I don't know why I thought the brass would be better.
P.P.S. Shipping was $3.75 on 3 packs of 5.
Can we make this an article??
Ed Kelle
>This is some good info to keep for the future and I know I would forget it where and what to order.
Can someone post this in the turning articles?
Re: Can we make this an article??
Bill Howatt
>I'll make an attempt to write it up with some additional info on why you would want to use them.
Bill
