Thanks Al Crandall! Vac chuck
Joe Tonich - Parma, OH
>Thanks to Al Crandall, I now have a vac. chuck. Al has writted very detailed instructions on materials needed (down to the aisle at Loews ) and construction of the chuck. My vac pump (an old fridge compressor) pulls 26Hg and I'm getting 20Hg at the drum when I put a piece of ply on to check for major leaks. I used a ball valve shut-off w/drain valve that works great for adjusting the vac. pressure in the system. The only thing is the fittings on the drum side of the tube won't fit thru the headstock of my lathe (JET 1236) so I leave it in after taking off the drum. I'm using a coupler on the end to protect the threads. I messed the threads on the end so when I do have to take it out for my steb drive, the nuts stop at the same place everytime I put them back on so the O-ring seats correctly when I reinstall it again.
It ain't pretty, but it is functional and will do till I get my shop in order.
Best of all, the pump was free (found a small fridge on the treelawn on trash day) and have under $40 in the chuck if I remember right.
You can find Al's write-up at http://www.woodcentral.com/bparticles/smvachuck.pdf I also want to thank my good friends, Travis, Jim K, and Dick P for their input and sending me pics of their set-ups. Hope when I get the shop set up right it looks as good as theirs!
Re: Thanks Al Crandall! Vac chuck
pic
Re: pic
Re: Warning - Rig Incomplete!!!
>Joe,
You are about to make the very same mistake I made with the rig you presently have. What you don't know ['till now] is that your compressor has an internal thermal limiter built in that wil trip and stop the pump until it cools down and resets. Now you also know what that little fan in the compressor compartment was for; to keep air flowing over the coils AND THE COMPRESSOR to prevent it from overheating. I know this because when turning on my vac chuck with my sealed dehumidifier compressor-cum-vacuum pump whispering away, the pump got hot, stopped, and before I knew what happened, my lovely bowl went parabolic into the far wall. Bounced pretty well though; both pieces.
You cure this little glitch by mounting a small fan like those used to vent stereo cabinets ($5 Radio Shack) into the circuit and aiming it at your sealed compressor's shell, which will then sit there and hum away all day with nary a burp.
Re: Example
Re: pic--material?
Ken Grunke from SW WI
>Joe, what's the foam you're using on this chuck?
I use craft foam with peel-off backing--"Foamies" in 9 x 12" sheets at Walmart. It's thin, moldable, high density foam that works pretty good and is cheap at about 60 cents a sheet.
Thanks for the Warning
Clem Wixted
Re: pic--material?
>Thats it. Bought at WallyWorld, and went with Red cause thats my oldest sons favorite color. 8^)
>Thanks Mark. Glad you said something. Being smacked silly from launched bowls definitely puts a damper on my day. Also glad I'm not the only one using one of these pumps. ;^)
Joe
Power loss
>I haven't lost one to vacuum pump shutdown but had the power kick off one day and had a bowl boucing around the room in a pitch black shop. That's exciting.
I thought it looked familiar!
>The stuff works great for jam chucks also. "Bout the only reason I'd go into Walfart!
One More Thing *LINK*
>Joe,
I went back and looked at your pix, and I don't see a filter installed in the suction line between the lathe and the compressor. You really must get one. Reid Tools sells a suction filter with rep[lacable filter cartridge the same push fittings as those that you've already adopted. They come in 1/4, 3/8 and 1/2" sizes and will cost about $15 plus shipping. Go to the link below, and, if necessary, put "SMC-8605" (8610 or 8615) in the search box. Your vac line will pull fine dust into the compressor without the filter and that will be deadly in short order to your "free" pump. These sealed system compressors are really not designed to tolerate debris in the airstream.
Good Luck
Reid Tool
Glad it helped.
Al Crandall (NE of Indy)
>The original article was written for the benefit of our club members, thus the addition of the aisle numbers of the nearest Lowe's store. I soon learned that Lowe's uses a lot of different aisle configurations in their stores. I wish I had omitted them before submitting the article for posterity. The finished product is ugly, cheap, easy, and totally functional. I now use two bearings in each rotary fitting, and epoxy a lamp rod connector instead of the tapered pipe fitting, in each chuck I construct. Glad you're up and running.
Al
Re: Power loss
Carole in VA
>Yikes! Never thought about that happening. We lose power a lot here. Wonder if one of those battery backups like I have for my computer would run it until you could shut the lathe down?
Re: Power loss
>Carol I think this was discussed years ago but I don't remember all the results. I do remember that we discussed putting a reservoir tank in line so that you had some time for the lathe to stop before the bowl fell off. I haven't tried it yet.
Re: Power loss
>hmmmmmmmm, never thought of that, but................why would ya need to power down if your electricity went out? Wouldn't the vac hold long enough for the couple seconds it takes the lathe to quit spinning?
Re: Power loss
Stuart Johnson
>The time I reached down and turned off the pump rather than the lathe I didn't even have time to say oh shxxucks before the bowl was bouncing off the wall.
Your experience is probably the norm.
>Most of the time, my pieces dislodge as soon as I open the ball valve "controlled leak". There was that one time, however, when I was worried that the piece would never come off. I had loaned the system to Jennifer to use during a demo, and I hadn't installed the control valve. I was using a new and untried gasket material, the funky foam sheet from the craft store. When she shut the pump off, not only didn't the bowl pop off, but the gage didn't drop either. I was hunting for a wrench to unscrew the hollow rod from the vacuum chuck which would break the vacuum. Another volunteer was banging on the bowl with his palm, and broke the seal just as I found the wrench. I had a valve plumbed into the line before I used the system again. We could have lost power and gone for coffee without launching the bowl.
Re: Power loss
Bill Howatt
>It probably depends highly on how porous your vacuum system is. This porosity is caused by plumbing leaks (should be very small), leaks around chuck/bowl interface and porosity of bowl itself. If you have a large amount of leakage but can still use a vac chuck because you have a big pump then when the pump quits you'll probably lose vacuum quickly. If you have a small pump then your total system is likely quite tight and the lathe would probably stop soon enough.
You have to factor in a dose of human nature as well, especially if you don't have windows or are working at night. When the power goes off you are plunged into darkeness and don't know where to put your hands to catch the soon to come loose bowl.
I was making a piece for a wedding gift that I couldn't afford to have a last minute disaster with so I put it on the vac chuck and then wrapped it with the stretchy clear plastic packing wrap just in case. Use the tailstock as long as possible is a good idea too.
Bill
