Bowl/Hollow form Steady Rest
Jim Ketron
>As most of you know I like to build my own tools and accessories when I can, and I have been putting off building this rest for a while. I was at the point doing all the hollow forms lately where it was a necessary item on the deep hollow forms to help keep the HF from being riped off the chuck, and also helping reduce chatter. I have built Mr. Big Mike Stafford a 4 wheeled steady and he informed me the design of the last one was bulky and needed to be reduced somehow ( it was square) Me and Mr. Travis Stinson had been talking in chat about what could be done to reduce the size and bulk of the original Steady and he come up with the great idea of making it a octagon shape. That has been over 10 months ago and I have been putting this off for that long Travis beat me to the punch, and already made his, He said it works great so I decided to go with his design
I have already used it and It works wonderful!
Re: Bowl/Hollow form Steady Rest
Carole in VA
>Darn, must be nice to be able to do stuff like that! I can't see it very well...I am assuming it is steel tubes welded together? I'll pay you to make one for me!:)
Chuck Ludwigsen
>Looks good, Jim. Mighty sturdy. I'm with Carol ;-).
BTW, nice reverse image of the guy in the hat in the window. Is that you or a peeping turner???
Chuck in Memphis, TN.
Jim Ketron
>Here is another View! I will try to get some up close pics in the day time hours.
Im thinking about selling a few! got to find out some facts first on a few things.
Dale Cook
>Hi Jim. Thanks for posting this,now I won't have to.The one I built about a year and a half ago is absolutly identicle to yours,other than the wheels are a different color.I guess great minds think alike.I even have the same lathe.
Craig Daymon
>Looks great and...I even have the same lathe...with the same twist plug!
One thought, although I doubt it impacts anything that can be turned, the square tubing that holds each rest on the octagon extends into the octagon. This (probably less than the lathe capacity) impacts the maximum size turning that can be used with the steady.
What if the tubing was brought back flush with the inside edge of the octagon and a triangular brace fixed to the back of that part that extends outside the octagon for additional support? This should make the square tubing very rigid. In fact, additional corner bracing at the corners of the octagon might help make the rig stronger (if necessary) being as the corners of the octagon are safely away from any turning since the wheels would be bigger than any added triangle need be.
Just thinking off the top of my head, but put me on the mailing list to know when you are ready to take orders.
-Craig
albertbob
>I love it am I am stealing it right now!
Actually, I was contemplating that very design that I think I saw in one of Mike Darlows' books if I remember.
I had planned to slot the base so I could move the hex off the nut without having to get under the ways to hook up and dismount.
Clever use of square tubing to set the wheels too.
Stealing, yes definitely stealing this one.
Bob
>I wish I had the tools to make one. It looks great to me.
Would it work just as well if the wheels were mounted in the corners of the octagon rather than the flats? Seems they would be able to retract further.
The flat bar across the ways takes up less room than the stock used on the wooden ones.
You aren't thinking correctly
Bill Howatt
>You should be looking at it as an opportunity (excuse) to spend a few grand on a good MIG or TIG welder, autodarkening helmet, metal-cutting bandsaw and might as well get a metal chop saw as well. Then you could save lots of $$$ by building your own.
On a more serious note, I inherited a stick welder and bought a metal-cutting bandsaw, found it to be one of the most handy things I ever bought just for cutting little pieces of steel, plastic pipe, etc for things I wasn't even going to weld.
Bill
ben d.
>Jim''
would you reply as to the tubing size 1 in. probably and the thickness.?? I do want to copy also and would appreciate this info. to keep from building too light then have to do over. I can get the remainder ok I believe.
