new grizzly lathe *LINK*
chris rolke
>a while back i had posted some info i had found about a new grizzly lathe
it is now on their site
1634.25 shipped
http://www.grizzly.com/products/G0456
chris rolke
1634.25 shipped
Re: new grizzly lathe
Mark Wollschlager
>Sturdy looking.
What is the deal with the outboard sanding disk?
mark
albertbob
>500 rpm bottom speed is too fast for most projects.
They are on the right track but they will have to address that speed thing to interest serious turners.
Bob
Bill Howatt
>It is a feature. When you reach for the handwheel you automatically get a manicure. Hmmm, maybe it's a bug, not a feature?
Bill
>I don't think it will touch the Jet 16" which is close to that price. The sanding disc would get in the way more than it is useful. My Dad had something similar and we used it to sharpen tools which is OK but not as good as a grinder. I absolutely hate gap bed lathes, I've owned 2 and the gap gets in the way a lot. The jet also has a low speed down to less than 100 rpm.
Ric Taylor
>John,
I have a Jet 1642, and the slowest I can get is about 140 rpm. Is there an adjustment that I'm missing? I would like to go slower.
Ric
>Do you have it on the slowest pulley. I don't own the jet but have the Powermatic 2035 which also has a converter drive. It will go down to zero. I had heard that the Jet didn't go as slow. The Jet 14 has a mechanical drive and won't go that slow but I thought the 16" would. Hopefully someone who owns one will be able to tell us. 140 is plenty slow for most things, even threading.
Ron Meadows
>Ric,
I have the 2 HP version of the 1642 and I can go down to about 80 RPM without loosing all control under load. Make sure that you have the belt installed on the lower speed range for it to work at this speed.
Ron
LOL! and the bed gap
Ken Grunke from SW WI
>Is plenty big enough for a disk of plywood. You can even put a Longworth chuck in there, amazing.
Keith Tompkins
>A segmented turner's dream come true?
Gap bed
Bill Howatt
>I know what you mean about gaps. My General 26020 has a gap bed and I bought the filler piece for it when I bought the lathe and it has never been removed. I also notice that my banjo is often over the gap filler.
Bill
Earl Eyre
>If anybody buys the new Grizzly I will be curious about how it performs. This looks like the same lathe I used to own but it had the Reeves drive. Not only did the motor never line up properly, all that sheet metal constantly vibrated and made all sorts of annoying noise. It looks heavy but all that base is just sheet meatl. The banjo broke and the tail stock never clamped down solidly. Personally, I'd stick with the Jet--I've never used one but it sure sounds like everybody is happy with it for about the same price. I finally bought to PM...
Earl
Ric Taylor
>John & Ron,
I have the 110V version, and I do have the belt on the slower pulley. My buddy and I went together and ordered two lathes a couple of years ago (reducing the five-month wait for delivery to five days). His low speed is about the same as mine.
If anyone knows a trick to reduce the rpm below 140 or so, I'm eager to hear about it.
Ric
>Your right keith. Set it up to sand your segments. Now if it just had a bandsaw on one end to cut the segments.
albertbob
>But the Jet doesn't have a sander! {g}.
I also wonder why they went with a 1-1/2"X 8 tpi spindle.
Seems rather a big jump from the rest of the pack and will require step-down adapter for most chucks out there.
I looked at it again and I think it's actually a 12" sander with an outboard lathe.
Bob
Re: Speed on Jet 1642
Karl in IA
>I have a 110V 1642. On low-range belt setting, it will turn at 45-50 rpm. On high range it will go down to 125-130 rpm. Torque is very good. Hope this helps.
Rob Wallace
>I've used Karl's lathe recently and had it at 50 rpm roughing a bowl - my 1642-2HP does the same minimum at around 50 to 60 rpm. Dies your speed control potentiometer have a full range of motion? Does it bind or get sticky at the low end? It sounds like a controller limitation, not the belt system.... (But just to ask, are you sure that the belt is completely moved to one side or the other on teh pulleys? Perhaps the pulleys are misaligned? Something to check...). BTW - I wouldn't go after Grizzly lathes at all....even with the 'pseudo-improvements'. Cheers,
Rob (also in Iowa!)
