Veritas - Innovation in Tools
Oneway Balance System on Delta Slow Speed Grinder
Philip Morris
>I am installing the Oneway Balance System on a Delta Slow Speed Grinder, Model 23-725 (the heavy one) and had several questions that I hope someone can answer.
1. How many machined washers are supposed to be supplied with the kit? There are only two with mine. The instructions state that both of the original dished washers are to be removed when installing the kit. It is obvious that the outside flange (the one with the groove for the balance bolts) has a recess for the washer. However, there is a steel shoulder on the shaft that the inner washer will butt up against. Just want to make sure that a washer does not need to be installed there as well.
2. The instructions show and describe two (2) balance bolt/nut assemblies being used per wheel, but my kit contains a total of six (6) of these. Are the extra assemblies in the event an out of balanced wheel needs more weight?
Thanks,
Philip
Re: Oneway Balance System on Delta Slow Speed Grinder
T Daniel
>Mine only had 2 per wheel also. I added one for one of my wheels that needed the extra one. I really don't think the balancing is needed on an 1800 rpm grinder and the nice flanges that One-way supplies aren't much better than the ones the Delta comes with; on other grinders the One-way flanges are worth their weight in gold. I do like the One-way kit; I just don't think it will improve what you have all that much because it should be pretty good already.
TD
Philip Morris
>TD,
Thanks for the response.
I don't have experience with other grinders so I was not sure about whether mine needed the balance system. I have noticed a slight degree of vibration, but thought it was minor. However, recent posts that this model was being discontinued got me thinking I should do what I could to prolong its usable life. I was given a gift certificate to Woodcraft and thought that I would try the balance system.
Thanks again,
Philip
Steve Roxberg
>I received two washers with my kit, one per wheel.
I actually called Oneway Tech support because they weren't clear on where the washer should go.
I was told to place it on the inside against the steel shoulder. I was told that the flanges are soft metal, and that the steel would cut into them if not protected by the washer.
Made sense to me.
In addition I have a Woodcraft slow speed grinder but the Oneway kit made a huge difference.
Enjoy.
Barry Turner
>Phillip, I have the Delta Slo=Speed too. It has served me well for about 4 years now. I use it with the Wolverine system. It has a bit of vibration and I have wondered if I would see a noticable improvement with the Oneway balancing system. It does a very good job as it is. I replaced the stock gray wheel with a 60-grit pink from Woodcraft, but am still using the stock 120 grit white wheel that came with the grinder. I have the Oneway diamond truing jig, but the one thing that improved the performance of my setup the most was the purchase of a $14.95 diamond dresser from Woodcraft. It helps immensely. If you don't have one, get one and use it often to remove the glaze from the wheels. They grind much better. Let us know how it goes with the balancing setup.
Vicmarc.fan
>I have the "cheap" new Delta variable speed with the Oneway kit. Before I added the kit I had to clamp the grinder down to keep it on the bench. With the kit I can balance a nickel on it running at any speed and it just sits there. Kit cost colse to what I paid for the grinder but I think it was worth it.
Ron
