Chuck Thread Adapter Problem
TomW in SouthJersey
>I was turning a large maple blank yesterday it was fairly heavy and green 13 inch diamter by 9 inches thick. When I was hollowing I had the lathe running in reverse and evidently didn't notice the Stronghold chuck was loosening. In a very short period of time I ruined the chuck's thread adapter. I thought I'd post this as a FYI for others. I don't remembering seeing this addressed. I have seen discussions on locking the chuck to the spindle. I guess this is the reason.
Here's an after picture. Maybe I can save someone the $25 the new adapter is going to cost me.
Re: Chuck Thread Adapter Problem
Bill Howatt
>Well, that's sort of the reason, the real reason is that the chuck and bowl will totally thread off the spindle and head for places unknown. Wasn't there any clunking sound? Frequently there is if the chuck, faceplate or workpiece is loose.
If you only ruined the adapter and not your spindle thread, consider yourself lucky. You might add to that the fact it didn't come off and hit you. I don't think it is a good idea to ever do any turning in reverse without the locking screws in place and be sure the chuck is real tight even if you are just reverse sanding.
Bill
Bruce in Saint John, N.B. Canada
>Tom from what I see in the picture there doesn't seem to be any great amount of damage unless its to the head stock spindle threads. Perhaps you are thinking the adapter is threaded out to the edge but such is not the case. The first two or three threads are removed in the manufacturing process, I believe it makes it easier to line up the adapter & chuck assembly and thread in on to the head stock spindle.
Bart Rhoads
>Your insert is probably not a total loss. You most likely can run a tap through the insert and clean up those bad threads.
Most lathes do not have the threads relieve so that you can us the set screw provided in the insert for locking the chuck for reverse turning. If this is the case with yours, take a piece of lead,like a couple of splitshot sinkers, that are large enough that they will just fit in the set screw hole. Place these in the hole first and replace the set screw. When the set screw is tighten it will squeeze the lead against the threads without damaging them and lock your chuck to the spindle.
Good Point!
Bill Howatt
TomW in SouthJersey
>Thankfully the threads on the spindle did not get torn up. The first few threads on the adapter are. I'll try taking it off the chuck and see if I can't clean it up to make it workable. I've already ordered another adapter but it won't hurt to have a spare. Maybe I'll find a spare chuck some day.
Thanks for the ideas.
Tom
>A local machine shop might fix that for you for a few bucks. They should have the correct tap and might even add metal if necessary by welding.
TomW in SouthJersey
>I just removed the adapter and used lots of oil and carefully threaded and rethreaded the adapter on and off the spindle. It is now functioning pretty smoothly. If I hadn't already ordered the replacement I'd save the $25.
Thanks for all the advice. Now I can go back to rough turning and hollowing the maple I got from a neighbor's tree that he had taken down.
Tom
