Speed ?
Roger
>Would like to know the opinions re: the recomended speeds for sharpening gouges, sanding and buffing. Thanks.
Roger
Speed ?
Roger
Roger
The slowest
Jorge Castaneda
>Roger,
Grinders working at high sppeds tend to burn the steel, so the slowest speed you can find is the best. Systems such as tormek, turn very slowly and in a water bath, so it is very safe way to sharpen expensive tools.
Belt sanders with a somewhat coarse grit, are also safer than the fast turning grinders, and sometimes you can use oil stones, or ceramic stones or diamond plates. There are also numerous grits of sanpaper, that have been used very sucessfully by hand tools advocates and that can be used in turning tools.
Jorge
Re: Speed ?
Bill Howatt
>For sharpening slower speed makes it less likely you will overheat the tool. You can overheat the tool with a 1750 rpm grinder if you apply lots of pressure against the stone and you can sharpen the tool safely with a 3450rpm grinder with the right amount of pressure. If you have high-speed steel tools the risk of overheating the tool is greatly reduced compared to carbon steel tools. There is no simple answer but rather what works best for you.
For sanding typically slower but this varies with the diameter of the workpiece. I would sand a 12" bowl at a much lower speed than a 1/2" dia pen. If the paper is getting too hot quickly you are going too fast but unfortunately there are a lot of other variables such as pressure, grade of paper and species of wood. Nontheless, you don't want to overheat the surface of the wood. For power sanding bowls with a drill, I run the lathe quite slowly and the drill fast.
For buffing, I adjust the speed of the lathe the get the firmness of the buffing pads I want. The faster the speed the firmer the buffs get. I never pay much attention to rpm numbers, I just adjust the speed until I'm happy. However, you must be careful that you don't exceed any recommended rpm for safety sake!!!
Bill
