Nasal health for woodworkers
Ken Grunke from SW WI
>Russ's mention of his dust allergies (see "Re: Age is relative" under the "Critique the Old Guy" thread) prompts me to mention a good treatment for many nasal problems, and also a preventive measure, that I use on a regular basis--nasal flushing.
Six years ago, I developed a bad case of nasal polyps, which are benign growths inside the nasal passage. Surgery was out of the question for me, being too costly and having no health insurance. My doctor advised against it anyway, saying it wouldn't be a permanent fix as they would likely reoccur. He prescribed Prednisone, along with a steroid nasal spray, which worked OK but was also expensive. I decided to quit the steroid stuff and see if nasal flushing alone would work, and it's done pretty good for me although the polyps tend still to flare up in the winter months when I spend a lot of time indoors.
Anyway, a warm saline solution is poured into one nostril, through the nasal cavity, and out the other nostril. May seem very wierd and uncomfortable if you've never done it, but once tried, it's not bad at all. Here's a website with more info:
http://www.chmkids.org/chm/ent/families/treatments/nasalwash.html
On this site, a syringe or bub irrigator is called for, but most people use a Neti pot, specifically made for the purpose. Just a small, usually ceramic, pot with a long snout--check them out here:
http://www.healingdaily.com/exercise/neti-pot.htm
Like I said above, it's not only a treatment for existing problems, but a great preventive measure for anyone who is exposed to dust and other allergens. If there's any segment of society that could benefit from nasal flushing, it has to be woodworkers--even if you use full protection in the form of respirators, dust collectors, etc. Give it a try, you might like it.
Re: Nasal health for woodworkers
and another:
T Daniel
>for ear infections (you'll get them if you let wood chips or lots of dust get inside) use a couple of drops of a 50/50 mix of alcohol and white vinegar. According to an old doctor who doesn't think all good medicines have to come from a pharmacy the alcohol gets rid of the water and the vinegar kills infection. I even use it in my dogs ears when I see him shaking his head. It works!
TD
>>...a warm saline solution...May seem very
>weird and uncomfortable if you've never done
My doctor once recommended this method for chronic sinus problems and it really works. He recommended a simpler method which sounds even worse but needs zero equipment other than what God gave you: pour a small quantity of warm salt water into your cupped hand. Lean over the sink, immerse both nostrils, and snort the liquid! (Do not swallow.) This sounds horrible but it is not and it is astounding how well it works, how immediate the relief, and how much it accelerates healing of even an acute sinus infection.
Carole in VA
>Yikes! I can't imagine how you get it in one and out the other!!! Seems like rather than do an about-face it would just run down your throat or worse, into your lungs.
Re: and another:
>TD, I should have also referred to your earlier post on the medication warning, I didn't see your most recent post regarding your own sinus problems. If you haven't tried the nasal wash yet I hope you do--it sure can't do any harm! And thanks for bringing to health issue to the forefront!
Keith Tompkins
Re: and another:
Keith Tompkins
>TD, I had chronic ear infections as a kid. the only thing that worked was what you just described!
>Carole, really, it's easy to keep it from going down your throat--the solution just flows through the nasal cavity and out the other nostril. Unless you have a nasal blockage like I have, but even then, it tends to enter your mouth before it goes down the windpipe. In that case, it feels no different from gargling except your head is tilted sideways instead of up.
Also worth mentioning, to allay other fears of discomfort, is if you have the correct solution and at the right temperature, there IS NO feeling of discomfort since the solution has the same PH as your body fluids. Plain water is somewhat uncomfortable, as is a too strong solution, both giving a stinging sensation.
Re: and another:
Sean Troy
>thats so strange that you mention this remedy. My wife is suffering from so pretty bad ear pain as I type. I just mixed up the solution and put the drops in. I'll keep you posted as to hopful improvment. Thanks for the post. It couldn't have come at a better time. Sean
Agree completely -- and more...
GaryG in MD
>I agree completely with Ken. I have severe allergies (not wood related) that cause me a lot of sinus trouble, and I "irrigate" my nasal cavities several times a day with a salt and soda solution.
For me, the simplest and most effective method is to squirt the saline into each nostril with a plastic squeeze bottle. This way you can change the angle of your head for maximum effect, and the squirting helps penetration. It just goes in your nose and comes out your mouth -- no problem at all.
For an applicator, I made a one-time-only purchase of a bottle of commercial saline -- just to get the plastic squeeze bottle. You can make your own saline solution by combining 1/2 teaspoon of salt and 1/2 teaspoon of baking soda in 2 cups of water. Heat a tad to dissolve. This feels very natural in your body. The tip of the applicator is not difficult to remove (with a thin piece of metal as a lever -- I use an old fingernail file) and replace for filling (with a small funnel). You can fill the squeeze bottle from your supply jar and then stick it in the microwave to achieve the temperature you like for use. (I do 28 seconds for about 99 degrees.)
I find that this helps me quite a bit -- indeed, I often can't breathe without it.
Happy breathing, Gary
Neti Pot instead
Darryl Hansen
>The alternative health people that my wife uses suggested a Neti pot for exactly what you are describing. It is a small porceline thingy into which you pour the saline solution (Use salt from Redmond salt in Utah to mix it up). Wroks for me and you should see the stuff that is frees up afte a day of turning. Almost as good (but not nearly just joking) as a dust collector. Do a serch for Neti pot and follow the links. About $12 for the kit pot and salt.
Re: Agree completely -- and more...
Ed Karch
>If you use kosher salt for your solution it is even more comfortable. Personally I use the snort method. It make take several days to clean out all the crud.
Critique Received
TomW in SouthJersey
>This is good timing. I read the earlier post and realized the nasal discomfort I've had for the past several weeks is probably an infection. I was turning some bloodwood yesterday wearing a decent mask and when I finished I still had lots of red "dust". I've been turning a LOT of cocobolo and rosewood lately.
I had just drawn some plans to build a small ceiling mounted dust collector using an old furnace blower and am heading to HD in a few minutes. I'm also going to wall mount a small fan near the lathe to blow the stuff away from me.
Happy New Year
Tom
Re: and another:
Stuart Johnson
>I've used this for years. The doctor said the same thing about the alcohol and vinegar mix. The doctor said the same about the alcohol and that the vinegar changed the ph factor which stopped the infection. He said it was just about the best thing for swimmers ear.
Chuck Ludwigsen
>Ken, you are right in everything you say. I've been using this for a couple of weeks now, got it at Walgreens. Have been breathing easier since the first treatment. I did get sinus headaches for the first day or so.
Chuck in Memphis, TN.
