Boiled linseed oil
Rick in Colgate, Wi
>A quick question, does BLO respond to buffing like danish oil does, or will I need to topcoat it with something? Thanks!
Boiled linseed oil
Rick in Colgate, Wi
Re: Boiled linseed oil
RussFairfield
>Danish Oil is Boiled Linseed Oil with thinners added to make it more useable. If not Boiled Linseed Oil, it is another oil, such as Soybean, with drying agents added to make it act and look like Boiled Linseed Oil. Some Danish Oils will have other resins added to it to build up a surface gloss, and some won't; but they are still an Oil Finish.
If cost is a consideration, it is lot cheaper to buy the Boiled Linseed Oil and add the thinners (Mineral Spirits or Naptha) yourself than to pay someone else to do it for you.
Timmy
>What kind of thinner would one add to BLO and at what ratio to have it perform like danish oil? Thankyou.
bulk linseed oil?
>Can you buy linseed oil in bulk, i.e., 30 or 55 gal drums?
I read a suggestion on another forum to treat rough-cut wood, i.e. barn siding and doors, with linseed oil as an inexpensive alternative to paint or wood treatment such as Thompson's.
They actually said "linseed oil", not "boiled linseed oil." Would the boiled be better for this application?
Re: Boiled linseed oil vs Danish oil
Niedling
>I think Danish oil is tung oil based and not Linseed oil. The Danish oil can does not list the type of oil. It only says that it contains mineral spirits for safety considerations.
Re: bulk linseed oil?
>Consider the boiled linseed oil as being "set-up" for polymerization. You remove alpha-tocopherol (vitamin E) from the raw cold pressed oil and "jump-start" the polymerization process. You could use straight linseed oil (anti-oxidants and all), but it would take a while to polymerize. Other drying oils would also work, but it is a question of how long they would take to dry.
Russ's article *LINK*
Ron in Drums PA
http://www.woodcentral.com/russ/finish7.shtml
Roger
>Don't know about the bulk oil. Do know that my Grandfather many years back used to brush raw linseed oil on new lumber a while before painting it. Then he mixed his own paint using white lead mixed with linseed oil and some sort of coloring if needed. It worked,used it that way myself, 'till the lead was removed from the market.
Roger
Jack Brown, Western PA
>For bulk, boiled linseed oil check with your local redi-mix concrete supplier. I just purchased it in a five gallon bucket. It is used on concrete for a sealer and a protection against salt. I believe this is what the highway dept. uses on concrete bridge structures to protect against salt deteration.
Can anyone answer?
Timmy
>Posted my questiot can't get an answer.
Tim,
>If you'll look in Russ' original answer just above your question, you'll see that he mentions both "mineral spirits" and "naptha" as thinners for BLO. To give you a bit further, mineral spirits is a rather slow-drying light oil thinner which will assist in deeper penetration into the wood surface; you may wish to add a bit of japan dryer with this solvent to assist in drying. Naptha on the other hand, has a much higher vapor pressure so it's much faster drying and will allow thinner "close to the wood" coatings. Personally, I use naptha only with film-forming resin/oil finishes like poly and varnish because it's better at allowing air in the liquid to escape and assists in eliminating lap marks. Naptha will, however, encourage sags and runs in vertical surfaces so it tends to be too fussy for finishing turnings.
That about what you were looking for?
M
Re: Tim,
Timmy
>That but not the sarcasm.
Sarcasm? Hmmm. . .
>If I'd wanted to be sarcastic, I'd have simply made a snide remark concerning reading prior posts before attempting to impune members for not answering your question that was already answered. Instead, I chose to give somewhat more detailed information concerning the two solvents Russ mentioned so that, depending upon your application, you could make a more informed choice, and inquired if that answer was sufficient for your use.
I don't deem that sarcasm, but if you do, I'll make it a point not to further antagonize you by responding to your future inquires on this board. I've got much better things to do with my time than trying to insult people who I don't know and will never meet.
Oh yeah
Timmy
>"I've got much better things to do with my time than trying to insult people who I don't know and will never meet."
Ok, save it for those that you know. I've lurked here for quite some time and you leave a trail of sarcasm and smart answers. Bye.
Re: Oh yeah
Wally Dickerman in Arizona
>Lighten up Timmy.....we're all friends here.
Wally
Re: Oh yeah
Timmy
>Your right wally and I'm sorry.
Allen Neighbors
>JKJ, I bought an old house that hadn't had a paint job in over 50 years. (I met the man that painted it last). The wood had greyed and was really in pretty bad shape, but I wanted to restore it without having to side it or brick it. I experimented over a period of about six months. Ended up mixing boiled linseed oil and naptha, 50-50. I put this mixture on the old wood, and the next day, put on the oil-based primer and then the top coat after a couple of days. The naptha helped to transport the linseed oil into the cells of the wood, and then evaporated. The linseed oil gave the paint some "tooth" to hold to, and is still looking good after 5 years. My
$.02 worth. AL
>John,
I tried some on my deck (treated SYP) after powerwashing and bleaching it one year. In 6 months the deck became gradually darker until it got to dark choclate brown. When I mentioned it to the gent I buy paint from, he told me that linseed is much more susceptible to mildew, and what I had was a very evenly moldy deck. It did power wash off rather easily the next spring, and I've not repeated the use; stayed with commercial preparations to which I add a mildewcide.
M
Re: Boiled linseed oil vs Danish oil... can labels
Ruth Niles
>If you read Russ's articles, or better view his finishing videos, he explaines all about can labels on finishing products. I learned an awful lot about what's in the can that's not on the label. Unfortunately I wouldn't depend on my memory enough to quote it for you here.
Ruth
Clorox
Jorge Castaneda
>Hi Mark,
Lindseed oil outdoors is a recipe for frustration, even if it does not mold it turns black, a simple antidote is to brush it with clorox and if possible to rinse it with water as well.
mis dos centavos
Jorge
RussFairfield
>I don't think that anyone directly answered the original question. Yes, Boiled Linseed Oil will respond to buffing, the same as "Danish Oil". Thin it 50/50 with Mineral Spirits, and use the same application as the Danish Oil.
The most common problems with buffing an oil finish are not getting enough oil into the wood, and not waiting long enough for it to cure before buffing. The directions on the Watco can tells you to keep the surface of the wood wetted with the finish for 30 minutes to allow for penetration before wiping it dry, and that is good advice for using any oil finish. Letting the wood sit for 5 days at normal room temperature should give the best buffed gloss.
There are 4 things to remember about commercial oil finishes.
The 1st is that "Tung Oil Finish" has become a generic term for an oil finish. It has nothing to do with what is in the can or bottle.
The 2nd is that the manufactures have figured out how to advertise and sell a product that contains some oil, sometimes a little varnish, and a lot of thinner at a high price.
The 3rd is that many of commercial oil finishes use Soybean oil, an oil that will not cure into anything without the addition of drying agents to provide the ozygen required to polymerize the liquid into the solid we call a finish.
The 4th is that Watco Danish Oil will forever and always be the oil finish of choice for most woodturners. The fact that it is more available than anything else we can put on a piece of wood other then Deft lacquer has a lot to do with that popularity. If you are using Watco, or any other commercial oil finish and you like the results you are getting, you like what it does to the wood, and you like how it ages, and you think the price is OK, why does it matter what oil is in it or what anybody else has to say about it??
As for the differences between Raw and Boiled Linseed Oil. The Raw form will only cure ON THE SURFACE, sealing off the oxygen source from the liquid oil under it. That fact makes it a good base for an oil paint on dry weathered wood on a barn because the uncured oil replaces the natural oils that have leached out of the wood, and that cured surface provides a primer for the paint.
However, we are not painting barns, and we want a harder finish on the denser woods that we use for furniture and turned wood. For that reason, we use Boiled Linseed Oil which has drying agents added to it so that it will plymerize into a harder solid that goes all the way down into the wood.
There is nothing wrong with using Raw Linseed Oil on turned wood so long as we remember what we are putting on the wood. Raw Linseed Oil would make a good salad bowl finish, except that it smells bad, nobody wants to use a salad bowl that stinks, and it can impart a foul taste to a salad. For those reasons, there are better choices for finishes on salad bowls. Personally, I would leave the Raw Linseed Oil on the barn.
Re: Bleach
>"Lindseed oil outdoors is a recipe for frustration"
Yup, Jorge, that's why I posted in response to John's proposed use. I had bleached the wood with oxalic acid prior to application. Didn't take long for the deck to look like . . . Fortunately, the film didn't hold up very well, and it was easy to powerwash off the following Spring. Stuff I use now gives me two years on horizontal surfaces in direct sunlight without darkening. Bit tougher to remove, but I got a bigger powerwasher last year so it evens out |;-}}
The Clorox is good to kill mildew; I use it in a pump sprayer to keep the foundation parge from going green. A tablet of pool clorine in a 5-gal bucket is even better.
HNY!
M
Re: Bleach
>>...Fortunately, the film didn't hold up very well
This seems to indicate the oil didn't penetrate well into the wood. Perhaps using it on pressure treated pine is less effective than applying it to dry wood. Since PT wood is often extremely wet, could it be that instead of penetrating, the oil dried in a film on the surface, trapping moisture below and promoting the fungal growth?
Thanks for the data points, I'm checking with some other resources as well. I'm not in a big hurry - perhaps I'll apply make some real-world tests with various boards and nail them to the side of my barn for a while.
Re: SYP
>John,
"old" deck (6 years then ), washed and then allowed to sit for 6 dry days before application with MC checked by meter at about 15% which is as low as it will get outside in my area. Wood soaked up the oil finish quite well (4+ gal. for 800 sq. ft.] and all "pools" were brushed out to prevent glossing. Gave the deck a really nice honey tone for about two months. Not again here.
Remember though, this failed primarily on a horizontal surface that gets direct sun and standing rain water. Since I assume your barn's walls are pretty much vertical [have a lot of "leaners" around here |;-}} ], your results may differ.
M
