We value your privacy.
>I have been turning some bowls where collars might work well, but I've never done it before. Can you point me to a place where I can get the details on how to turn and add a collar?
I can imagine several ways to do it, with glue up after the fact, and before the fact, but I don't want to reinvent the wheel.
>I think most people turn the collars "aftermarket"- that is to say not attached to the vessel. The base of the collar tends to be the largest part, meaning you can make a larger entry hole to hollow through. Larger holes make it much easier to turn and also remove chips.
I'd recommend that the create a little step in the collar base to register in the entry hole. I'd also recommend that you try to remember to align the collar grain with the vessel grain to minimize the chance of splitting the collar due to expansion. I use CA glue to attach.
1. I make my collars with a "step" in the base. This acts like a round mortise, which accurately centers the collar on the form, and doubles the glue-surface area.
2. I form the tenon on the collar first, ensuring a good fit in the vessel. At this point the collar is mounted in a chuck directly or on a waste block. I make my collars in spindle grain orientation for stability, not in bowl grain orientation.
3. I glue the collar to the vessel, then shape the exterior of the collar...that way I can follow the contour of the vessel. If you can't somehow visualize the two components together, the collar usually ends up appearing as though it is just sitting on top of the form. I try to make the form flow right through the collar for a continuous effect.
4. Color...I try to make the color of the collar compliment the color of the form. I think a yellow and red or orange combination is hard to pull off. Ebony seems to go with almost everything...
>If you're a member of WoW, go to Reviews and do a search for collar. You'll find a tutorial complete with several photos.
When I put a collar on a vessel and the opening will be small, I attach the collar after the piece is nearly completed. If the opening is fairly large I usually glue on the collar material before the final cuts on both the inside and outside.
