Moveable control for General lathe
Dave Shombert
Dave Shombert
>I have a General 26020, circa 2000, that I'm very satisfied with, but I had always wished it had a "remote" - a way of positioning the on/off and speed control wherever I wanted it, so I wouldn't always have to reach to the front of the machine (a little inconvenient when hollowing, especially if you're straddling the bed). Not long ago, I had a chance to use a new version of this machine and it had just that - the controls were in a box tethered to the electronics by a cable. I inquired about getting one of these from General and adding it to my lathe - a couple hundred bucks, and dire warnings about the complexities of hooking it up. But in looking the thing over, I realized that there's nothing more to this than just (a) unscrewing the metal plate that holds the switch and speed control, (b) mounting the plate on a box, and (c) hooking everything back up - via a long cable - to the same place in the electronics as it was originally.
It worked great. I needed six feet (about $20 worth) of six-conductor (stranded #20 wires) shielded cable, a scrap of wood (apple, in case you're wondering), and a couple rare earth magnets. Plus a scrap piece of 1/16" steel plate to cover the hole in the machine where the controls used to mount. Now I can have the controls within easy reach no matter what I'm doing - on the bed, on the side of the machine near the tailstock, or anywhere else. And there's nothing complicated about this electrically, everything is connected exactly as it was at the factory. No more, no less. It's just six feet of cable outside the machine instead of two feet of cable inside the machine. I would think this approach would work on some other lathes. I'm embarassed that it took me five years to think of it. Duh. Attached is a photo showing the box stuck on the headstock with its original location just below it. I'll follow this with a few more.
Dave Shombert
Elkins, WV
Re: Moveable control for General lathe
Dave Shombert
Close-up of the box
Dave Shombert
Dave Shombert
Back side of the box
Dave Shombert
Dave Shombert
Box & cable, tied into electronics
Dave Shombert
Re: Good thinking. Is there strain relief?
Al Crandall (NE of Indy)
>A like the solution you came up with, but I worry that the cord has no provision to keep it from being pulled out of the box if it gets caught on something while moving. An external cord clamp or a UL knot on the inside would add a measure of safety. Again, you did a great job. Others contemplating a conversion like this might consider using a metal weather tight single gang box and cover from the home center. It would make it easier to install a cord clamp. I predict a run on 6 conductor cable happening soon.
Re: Close-up of the box
adrien
>Wow, Dave! Thanks for the article. I had tried the remote from General, but was forced to return it because the magnetic back wouldn't hold through the heavy paint on the lathe body and the switch kept falling. They refunded my money without complaint. I wonder if it wouldn't be possible to get an extra switch and rheostat�or whatever the speed control is�so that one could have both switches (Al Crandall what do you think?)
Gotta try this....
Keith Tompkins
Keith Tompkins
>HI Dave, I see the newer versions come with such a moveable box....good idea!
Be careful
Bill Howatt
>Be very careful if you plan on moving the On/Off pushbuttons as well. They have the FULL 240V line voltage on them (at least my 3yr-old 26020VFD has) not the 24V control voltage.
I did my On/Off, as well as the speed control pot. I didn't bother with the reversing switch. I built a secondary box which mounts near the VFD controller enclosure for switching the 240V and just used 12V for the ON/Off switches which I moved. Also, having the On/Off near the speed pot helps you see what the pot is set at before turning the lathe on - just in case you put a new rough blank on and the pot is turned to max speed.
I tried to remove the speed pot from the General panel but couldn't figure out how to get the knob mechanism off so I bought a new pot.
I doubled up the wires to the speed pot since I don't know what happens if it loses the ground. Does it run up to full speed?
Bill
My Control Box
Bill Howatt
>General Switches moved to a plastic electrical enclosure bought at HD. As mentioned earlier I couldn't get General pot out so I bought a new one and I like the knob I had better since the numbers are larger. Cable is doubled because I didn't have enough conductors in one and I used the extras to double some of the speed pot connections. The cable normally hangs down the back of the lathe.
I find the wooden box mount to be very secure and easy to move around (it is not magnetic, just sits in ways), typically from one side of tailstock to other depending on whether it is being used or not. I also have a mounting platform on the wall at the tailstock end of the lathe but I haven't used it much.
An advantage of converting the control voltage to 12V from 240V is that I can easily put other emergency Off buttons wherever I want. I have one on the headstock side of the lathe on a table that is always located there.
Bill
Dave Shombert
Dave Shombert
>Hi Al,
Good point, strain relief IS important on something like this. I neglected to mention it, but it's there - you just can't see it. I thought about using a line cord srain reliever, but I think it would be hard to do given the thickness of the wood. THose things are designed for use in an electronics chassis. What I did was fasten a plastic cable tie (tightened) around the cable just inside the box. I'm pretty sure that will stand up to any tugging on the cable. I did the same thing where the cable goes into the lathe's cabinet (the electronics box), and there I put two cable ties - one on the inside, one on the outside, so that the cable can't weasel its way into the box. I should put one on the outside of the controller box, and I will, but at that end the cable is much more firmly held in place by the fit in the hole.
All of this reminds me - I also put a rubber grommet in the hole that I drilled in the sheet metal of the electronics box, to protect the cable from the metal edge.
Dave
Re: My Control Box
adrien
>OK Bill, a pot is not a ceramic bowl, I take it, but a potentiometer?
How did you convert 240 volts to 12?
Re: My Control Box
Bill Howatt
>Yes, a pot is a potentiometer. I used a good quality one not a real cheapie.
For the 12V, I just used a suitable surplus plug-in transformer from something that got scrapped - the big black plastic blob with the 120V pins sticking out of it; also sometimes called a "brick" for more slang.
Actually this is something I would like to fixup by getting a 240V primary 12V or so secondary or even 2 120V primary, 6V secondary that I could connect in series. I would put this inside the metal box that contains the General's VFD controller unit. Right now I have the 12V cable from the brick going down my box containing the 12V voltage regulator and 2 relays. Works fine but isn't real elegant. Since the lathe was still under warranty I was doing this with minimum changes to the lathe itself such that everything could be restored to original condition if necessary.
Bill
